West Coast Mirrors
West Coast Mirrors
If I understand correctly, my truck has the "West Coast Mirrors." As you can see in the photo (only one I have showing the back side of the mirrors), there are convex mirrors attached to them.
I presume the convex mirrors are not stock. Frankly, I find them irritating, so I am thinking of removing them. Is this a bad idea?
Is there some reason why these mirrors would not do well as originally designed? Do I need the convex add-ons?
No, they are not "stock", they are probably stuck on with 3M tape. I bet the PO put them on.
Should peal off easy or use a hair dryer to warm up the tape, then peel easy.
Do not use a screwdriver to pry on them directly, but maybe a wide putty knife wrapped in a rag?
If you have to get a little more effort, use the metal mirror body edge to get some leverage with a longer screwdriver. Yes I know I said to not use a screwdriver, but you get my point, right?
Not towing, but I do like the blind-spot coverage. I think I will go with the idea of smaller convex mirrors down in the corners. Thanks!
Oddity
Here's an oddity on my '71 F-250.. Typically on the back of the mirror heads have either have "FoMoCo" or the Ford ovallogo. I have "Rotunda" on the back of a mirror head. Unfortunately the PO broke one moons ago and replaced it with a dime store version. I replaced the generic head with a spare head so it at least looks OEM.
These were the over-the-counter kit for those who didn't opt for them when first sold. That makes sense because the door still has a plastic plug and screw holes where the standard mirror was mounted.
Lemme know if any of you have a spare "Rotunda" mirror head cuz I'd be interested.
mudrat025
26
11-17-2017 10:37 AM
