5.0L Coyote 5.0l Ford OHC Coyote engine for 2011+
5.0L Coyote problems
Old 09-10-2014, 11:56 AM
60F100's Avatar
60F100
60F100 is offline
Does the 5.0 have any of the same problems that the 4.6 and 5.4 had.Specifically the chain tensioners and the spark plug problem. Are there any other known problems.
Old 09-24-2014, 03:48 PM
Buck268's Avatar
Buck268
Buck268 is offline
Lots of views, no replies. I have not heard of any major or frequent problems, either. Well the misfire/stumble from factory over-gapped plugs but that is hardly a major issue. And some people believe the low mounted alternator is a problem in wet conditions, but it hasn't been for me.
Since you specifically asked about the plugs, I can say (since I've replaced mine) that Ford has learned from their previous experience Curious to see about the cam hardware as people rack up miles, though.
Old 10-01-2014, 07:40 PM
chruby99's Avatar
chruby99
chruby99 is offline
these are 2 different engines. No this is not the same motor or platform as the romeo 4.6 5.4 engines. there are some common dimensions , rod lengths but two different engines
Old 05-04-2015, 09:34 PM
sky Cowboy's Avatar
sky Cowboy
sky Cowboy is offline
The 5.0 has been extremely rugged for me. I love this engine.
Old 09-12-2017, 08:17 AM
Big Bad's Avatar
Big Bad
Big Bad is offline
The 5.0 is considered a member of the Modular family by Ford.
Same deck height, bore spacing, main journal diameter, head bolt pattern, rod length, etc.
Oiling system and the basic valve train are also the same, the primary difference being the CTA cam phasers.
The 5.0 is just a Gen 2 Modular.
The 5.0s do not have spark plug issues, nor has any previous 4V Modular.
Old 09-22-2017, 08:09 AM
ubereal2's Avatar
ubereal2
ubereal2 is offline
Al I've heard/read about is from the 2011, and 2012 5.0 are rattling noises from cylinder walls distorting. That was fixed by 2013.
I've had a 2011 5.0, and now a 2013 5.0 and have had zero issues from either truck/engine.
Unk Bob
Old 09-22-2017, 07:24 PM
92F350CC's Avatar
92F350CC
92F350CC is offline
I haven't heard of any other than that cylinder issue on the first couple years as mentioned above.
I think the Coyote will go down as one of the best V8 engines ever designed. It's really a shame that it came at a time where Ford frankly doesn't give a flying f**** about V8's and will probably abandon it.
Old 09-23-2017, 03:52 PM
sky Cowboy's Avatar
sky Cowboy
Something that most probably do not even think about is the sound it makes.
While I don't know why, it seems to make sweeter music to my ears than many other V8 engines do.
I like spinning the coyote to 6000 just to hear it sing.
While most V8 engines sound good...some sound better than others to me.
Old 12-23-2017, 02:16 AM
Sheepdog728's Avatar
Sheepdog728
Sheepdog728 is offline
First off let me start by saying i am not mechanically inclined..... at all. I have a 2011 Ford F-150 FX4 5.0 always use full synthetic 5W20 Motorcraft oil every 5k miles (at 110k miles currently), my last oil change was on Monday and the tech at the ford dealer said it looked like I have a slight rear main seal leak. (I check the oil every couple of days, always have, habit after owning a 5.4 and 4.6 Interceptor) I have noticed the oil being low recently and didn't think anything of it because it hasn't really been all that low maybe a quart over the course of 5k miles. I never see any oil drips in the driveway. After reading about rear main seal leaks I am now terrified, do i fix it? do I just keep adding oil until it gets worst? is it even a rear main seal or is it an oil pan gasket?..... the worst part is after giving my girlfriend all sorts of crap about how my 5.0 is better than her '09 5.4 this happens
Old 12-23-2017, 02:20 AM
Sheepdog728
also bought it brand new in 2011.... 13.1 miles the day i got it always keep up with maintenance
Old 10-05-2018, 06:37 AM
ArmamentDawg's Avatar
ArmamentDawg
ArmamentDawg is offline
The 5.0 Coyote engine is by far the BEST engine Ford has made in decades. I just purchased a used 2015 F150 4x4, SuperCrew and now own two cars with the Coyote engine under the hood. The other car is it's little brother, a 2016 Mustang GT Premium. Both in Ruby Red! And soon to have matching painted on stripes! My Coyotes have been trouble free since day one. Very smooth and powerful. The old 5.4 ltr had a propensity to launch the plugs from the heads or break the spark plugs off in the heads if the truck was built pre-2008. no longer an issue.
Old 05-28-2020, 12:22 PM
oldfordcoupe's Avatar
oldfordcoupe
oldfordcoupe is offline
Question
well i just had a service eng. soon light on took it to dealer today said i had a #5 cyl. low comp. taking it back monday we will see???
Old 05-28-2020, 12:23 PM
oldfordcoupe
it,s a 2014 with 90 k on it
Old 06-13-2020, 08:43 AM
rougerocco's Avatar
rougerocco
rougerocco is offline
I have a 2012 with 326K on it. Runs great, been maintained by dealer for everything!!
Katmandu
Modular V8 (4.6L, 5.4L)
18
05-22-2013 11:16 AM
1912barry
1997 - 2003 F150
03-15-2010 07:00 AM
oscar_007
1997 - 2003 F150
09-29-2006 07:09 AM
JF5speed
General Automotive Discussion
03-14-2005 08:44 PM
cyc79
12-24-2004 06:28 AM
Quick Reply: 5.0L Coyote problems
