Go Back   Ford Truck Enthusiasts Forums > Misc. > Towing, Trailers & 5th Wheels
Sign in using an external account
Register Forgot Password?
Towing, Trailers & 5th Wheels SPONSORED BY:
Old 09-10-2014, 07:11 AM
gfw1985's Avatar
gfw1985 gfw1985 is online now
Amatuer Restorer
gfw1985 is a name known to allgfw1985 is a name known to allgfw1985 is a name known to allgfw1985 is a name known to allgfw1985 is a name known to allgfw1985 is a name known to all
Car Hauler Winch Battery
Getting ready to install a 9.5Klb winch on my car hauler. Going to mount it on a hitch mount receiver welded to tongue to make it removable and to hitch mount to my truck.
1) Will the stock 7 pin wiring charge the battery?
2) I'm concerned that the winch will overload the stock truck wiring when in use. Should I disconnect the trailer plug when using the winch?
3) Figuring on a 700CCA deep cycle marine battery. I can fully charge battery once home with my large charger. Any thoughts or opinions? Cost of wiring the truck would be another $175-$200 that I'd rather not spend right now.
__________________
66 Bronco Half Cab, 203ci I6, CI aluminum head and intake, Isky 256/256 cam, Keith Black pistons, Clifford header, Holley 390cfm 4v, 9.7:1 comp, DSII ignition
55 F100 Build in progress http://www.ford-trucks.com/forums/13...100-build.html
Old 09-10-2014, 10:44 AM
thomabb's Avatar
thomabb thomabb is online now
thomabb has a great reputation on FTE.thomabb has a great reputation on FTE.thomabb has a great reputation on FTE.thomabb has a great reputation on FTE.thomabb has a great reputation on FTE.
I suggest integrating a single pole double throw switch to the +12v side of the trailer battery. One position wired to the +12v side of the winch, and the other wired to +12v from the truck. That way you can't accidentally run the winch off the truck feed and burn up your wiring harness.
__________________
'02 F250 7.3 Auto Extended Cab Long Box 225+k Miles No Mods
Old 09-10-2014, 10:47 AM
thomabb's Avatar
Amazon.com: Gardner Bender GSW-117 Heavy-Duty Toggle Switch, 20A 125VAC, Single Pole Double Throw, (ON)-OFF-(ON): Home Improvement Amazon.com: Gardner Bender GSW-117 Heavy-Duty Toggle Switch, 20A 125VAC, Single Pole Double Throw, (ON)-OFF-(ON): Home Improvement
Something like this. You will want to make sure it can handle the max amp draw of the winch.
__________________
Old 09-10-2014, 01:57 PM
meborder's Avatar
meborder meborder is offline
meborder has much to be proud ofmeborder has much to be proud ofmeborder has much to be proud ofmeborder has much to be proud ofmeborder has much to be proud ofmeborder has much to be proud ofmeborder has much to be proud ofmeborder has much to be proud ofmeborder has much to be proud of
Quote:
better yet a SPDT relay. (a normally open SPST would actually be better)
hook one side of the relay coil to the B+ lead from the truck, and the other side to the 12v switched leg of the winch motor.
run the common pole (30) to the trailer battery
run the normally open pole to the B+ lead on the truck
leave the normally closed pole open.
this way when the truck is running, the relay coil activates and the voltage runs through the relay and charges the battery. when you activate the winch, the relay coil sees 12v on both legs, and will close the relay to the normally closed position, thus disconnecting the trailer battery from the b+ lead on the truck.
all automatic and idiot proof that way
harder to explain that to do....
__________________
Mike
2004 F250 SD SCREW; V10, 4R100, 3.73's -- 2006 Expedition XLT; 5.4 V8, 4R75 3.73's -- 1979 F350 Trailer Special; 460, C6, 4.10's
Moderation Guidelines and how they are enforced
Be yourself - Always ... Unless you can be Batman, then Always be Batman
Similar Threads
Suggestions for wiring car trailer winch phydeauxman Towing, Trailers & 5th Wheels 8 04-29-2014 03:34 PM
My car hauler now has a pullie thingy jniolon 1948 - 1956 F1, F100 & Larger F-Series Trucks 16 05-16-2013 01:33 PM
Winch recommendation nuclearwhiskey Escape & Escape Hybrid 4 06-21-2012 12:32 PM
question about hooking up auxiliary battery on trailer? hasteranger Excursion - King of SUVs 7 02-29-2012 06:13 PM
12v Power 7pin Trailer Enuff Power? JIMRSX Super Duty & Heavy Duty 6 04-05-2008 03:16 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Participate In The Forums
Create new posts and participate in discussions. It's free!
Sign Up »
Powered by vBulletin® Version 3.8.7 AC1
Copyright ©2000 - 2015, Jelsoft Enterprises Ltd.
Advertising - Terms of Use - Privacy Statement - Jobs
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
vbulletin Admin Backup
