26 Gallon Fuel Tank on the F-350 6.7 Diesel
I just bought a 2015 F-350 Diesel only to find out is has a 26 gallon fuel tank. Is there some reason Ford only put a 26 gallon fuel tank on a vehicle that is designed to pull large and heavy loads? When I pull my 15,000 lbs. fifth wheel I get 8.9-9.1 miles to gallon, thus, I am filling up every 200 miles.
Is this an EPA requirement or what. My Ram 1500 had a 32 Gallon tank and the F-150 has a 36 gallon tank for the 6 cylinder??? A larger tank is not even an option on the F-350 SRW short (156") wheel base.
It used to have a bit larger tank but they had to reduce it to add the def tank.
There are some aftermarket tanks or in bed fuel tanks that can help though.
A small part is the shorter overall length, but as you pointed out, bigger tanks fit in other short vehicles. Maybe it was done because that's all the soccer mom crowd needs, or maybe it was to prevent sticker shock from having to fill up a large tank.
Either way, as Senix mentioned, either a bed mounted auxiliary tank or something like a Titan replacement tank is the route most who have a short bed and haul a bunch have followed.
rsyauto
6.7L Power Stroke Diesel
11-12-2013 12:57 PM
