So how bad did I hurt my motor? Worth fixing, or toss for a 6BT?
Old 09-22-2014, 03:05 PM
Kert0307's Avatar
Kert0307
Kert0307 is offline
Originally Posted by Jeff Watts
Did you do the work yourself? Is there a build thread?
Yes, I did it in about a month and a half working on weekends.
Here is some of the swap. With injectors, turning up the pump and some turbo mods, I'm up to stock 6.0 hp with more torque and cool egts.
https://www.ford-trucks.com/forums/1...mins-swap.html
  #62
Old 09-22-2014, 03:21 PM
Kert0307's Avatar
Kert0307
Kert0307 is offline
As far as cost goes, I had about 4k into swap parts, 3.5 k into the motor. Parted out my 6.0 and made about 3k back. Most of the swap cost is adapting the 5r110 to the Cummins. If you use a donor Dodge with a manual trans and swap to a manual it could be done fairly cheap.
  #63
Old 09-22-2014, 07:15 PM
cheezit's Avatar
cheezit
cheezit is offline
If I spent a little time hunting I could find 2 6.0 engines for $7500 and have my truck back in a day.
  #64
Old 09-23-2014, 02:04 PM
Kert0307's Avatar
Kert0307
Kert0307 is offline
Here's the thing. I do agree with most of you that in most cases it is better to fix the 6.0. I really have no problem with them once you do some research and know what to look for and how to maintain them, they are good motors with a lot of power potential and reliable. But, if it comes to the point where the motor for lack of a better term is "totaled" the cost of ownership and maintenance of a 6bt looks pretty appealing if you are mechanically inclined and planning on keeping the truck for awhile.
I mean really what's not to love about a truck with modern creature comforts and a simple as dirt reliable engine that is cheap to maintain and get parts for?
I'd argue that unlike the gas carburetor/fuel injection argument, as diesels have "advanced" they have become less user friendly, more costly, and less reliable. The only thing they do better is make more power per cubic inch and satisfy epa personnel who have no idea how an internal combustion engine works or runs efficiently.
  #65
Old 09-23-2014, 04:43 PM
Jeff Watts's Avatar
Jeff Watts
Jeff Watts is offline
Kert, you're at about 350 HP? How much black smoke does it put out under throttle? I want to NOT be one of the coal-rolling brodozers.
  #66
Old 09-23-2014, 05:03 PM
Kert0307's Avatar
Kert0307
Kert0307 is offline
I'll be honest, if I go from a dead stop and stomp on it it will smoke. I have my pump ("VE" not a "p") turned up pretty far, but I have the fueling ramp rate backed out as far as possible. Under normal situations it doesn't smoke, but it will smoke if you get in it before it spools. Once it's spooled, even under full throttle pulling 30 psi boost it really doesn't smoke. It's all about matching your turbo and pump timing to whatever injector you run. Egt's run at least 200deg cooler than my 6.0 ever did.
Smokes about as much as my 6.0 did with Power Hungry's 50hp ecm tunes...
  #67
Old 09-24-2014, 11:38 AM
parkland's Avatar
parkland
parkland is offline
The only bad part, IMHO of the cummins is the straight pipe exhaust drone and noise, man are they ever loud, even at low output they can be very annoying.
Jesser02EX
02-20-2015 08:52 PM
sand_fiend
16
11-15-2013 11:22 AM
Knox
05-10-2010 07:03 PM
Sycostang67
119
06-15-2009 10:49 PM
ewellman
Oil & Lubrication
10-06-2003 08:52 AM
Quick Reply: So how bad did I hurt my motor? Worth fixing, or toss for a 6BT?
