ignition/ gauge question?
Ok well truck started making a funny noise once I started it the other day. Think starter was going. It dies and keeps trying to turnover with key off. So pull the post off that's melted to the battery. I replaced ignition switch I'll see tomm if it works. Let me know of any other ideas. And 2nd question since I got the dash apart I want to try and hook up the p/d/r... how do I do that.. any video I don't know what to search.. thanks
Just went through that with my truck. Be careful of what Napa sells you though. The "standard" unit that they sold me was Echlin, which used to make good stuff, but apparently now falls into the cheap Chinese junk category. After burning up a couple of them, one failed on the second start, they got an Ametek unit for me instead and that, so far, has lasted just fine.
Interestingly, the Ametek solenoid is made in Mexico. A place that years ago everybody railed against. But it does appear that quality stuff comes out of Mexico now.
I'm not sure it's really unknowingly. Instead I think that we as a nation are losing our ability to think critically. People don't stop and think about what they are buying. They just listen to endless advertising telling them that brand X or store Y has the lowest prices. The focus is on lowest prices and nobody talks about quality. Therefore the average consumer doesn't even stop to think about it.
If your starter solenoid keeps blowing, it is a symptom not the cause.
You say you have trouble with hot starts.
This is usually the starter windings on their way out or a bad starter cable.
Change the cable if it is at all suspect (they're cheap in comparison) and check the battery ground connection to the block of the truck while you're under there.
Any component in the circuit that is not up to the job will cause unusually high current to flow through the solenoid contacts, welding them together.
If the battery terminal is melted to the post, start by cleaning those connections and use terminal grease or spray to protect them.
Why???
You don't need a relay meant for continuous duty if the duty cycle is a few seconds at most.
Intermittent duty relays would probably have better contacts meant to control arcing anyhow.
Tom Rowe (Rovernut) would try to sell you on a Cole-Hersee one with silver contacts.
These do have better conductivity and are less likely to weld.
Jmschneider
18
10-12-2015 11:51 PM
