need help identifying rear leaf springs
Old 09-27-2014, 07:20 AM
RobRoss's Avatar
RobRoss
RobRoss is offline
You're welcome. Your pn is just an older V than what is generally seen here. I think the "Y" means 2000 model year. 5310 is the base pn for all front springs and generally the base is not on parts, just the prefix and suffix. ..but I'm no expert.
Old 11-27-2014, 03:14 PM
andym's Avatar
andym
andym is offline
Rob what are you using to decode the part numbers? I have a line on a set of springs but they're off the truck. I'll need to look them up by part number to figure out what they are.
Old 11-27-2014, 03:25 PM
RobRoss's Avatar
RobRoss
RobRoss is offline
I'll be happy to look them up for you.
Old 11-27-2014, 03:45 PM
andym's Avatar
andym
andym is offline
Can I call you on a Sunday morning from the junkyard to ask you to look them up for me?
Is it a secret?
Old 11-27-2014, 06:45 PM
RobRoss's Avatar
RobRoss
RobRoss is offline
Is it a secret?
It's best for me if you write them down, post em here and I'll get back to you on Monday.
Old 12-01-2014, 05:19 PM
andym's Avatar
andym
andym is offline
Ok Rob, I have a guy selling some springs and they're already off the truck.
The rear says:
RPN 1962
2C34 CB
The front says:
YC35 AMC
R 286 0
Any idea what these are?
Thanks!
Old 12-02-2014, 07:36 AM
RobRoss's Avatar
RobRoss
RobRoss is offline
It took a while, each part number changed a few times and made it a tad confusing. If I'm right, you have V and B codes. Do the rear springs have an overload spring? According to what I saw, they should.
Old 12-02-2014, 07:54 AM
andym's Avatar
andym
andym is offline
They do have an overload spring. I did some googling and arrived at the same conclusion you did so I snagged them last night.
Ready for this? Picked up all four springs for $170. He was going to give me the hardware too but since all I need are the springs he kept them.
Old 12-02-2014, 08:19 AM
RobRoss's Avatar
RobRoss
RobRoss is offline
Good deal, I forgot to mention the fronts are 1999 and the rears are 2002. Take a look at the bushings, now is the time to change them.
Old 12-02-2014, 05:22 PM
Restlesswildman's Avatar
Restlesswildman
Restlesswildman is offline
Rob do you have a list of spring part #'s that you could post for a reference in the future?
Old 12-02-2014, 06:37 PM
RobRoss's Avatar
RobRoss
RobRoss is offline
Sorry I don't, I research them one at a time. When I get sometime I'll try to make a list.
Old 12-02-2014, 08:17 PM
RobRoss's Avatar
RobRoss
RobRoss is offline
When I posted I was thinking of front springs. For the rear I have a spreadsheet that lists rates and transition points that's semi interactive. You can input a load and it will calculate position and whether you are in the primary or secondary rate. It also calculates natural frequency. I sent it to one of the moderators with other info but never heard back...I'm guessing he never read any of it because it helped me decide on my springs and I'm certain it would help others.
Again, I'll try to compile a list of part numbers...just not sure when.
  #28
Old 01-19-2015, 10:17 AM
superdave02f552's Avatar
superdave02f552
superdave02f552 is offline
Time to awaken a sleeping thread.
How about these numbers rob.
F81a afd rpn 1279
  #29
Old 01-20-2015, 02:59 PM
RobRoss's Avatar
RobRoss
RobRoss is offline
F81a afd rpn 1279
I got a bad cold, give me a few days.
  #30
Old 01-20-2015, 03:35 PM
superdave02f552
well since your helping me that would be ok........yes thats cool hope you feel better
Quick Reply: need help identifying rear leaf springs
