Could I be cooking my carrier?
I've had a lot of work done to Stinky's running gear since May, and I'm still in the throes of chasing down the last vibration in him. I've paid particular attention to the driveline, pulling it and having it spun in the shop more than once. I've tried the carrier bearing shim, but it only exacerbated the vibration. I recently checked the temperature again, and I spotted something I don't remember seeing before. While aiming the sensor directly at the bearing, I got a reading of 150 degrees F. I grabbed the driveline next to the bearing, and it was hot to the touch.
As I mentioned, I don't remember this much heat before - but my memory is feeble. Has anybody else checked their driveline for heat near/at the carrier bearing?
Tugly, You ask a great question. What is the operating temperature range of the rear axle? I just shot mine with an I.R. gun and it was 120*. I looked up Dana S-135 operating temperature and did not find anything. On the automatic transmission 70*-100* above ambient is considered in the normal range. Does the rear differential have a similar range?
A temp of 150 would be completely normal for the differential in the summer time.
Sorry for the derail, I read carrier and jumped on differential. Need to work on reading comprehension.
Might be yours is a good bit too hot. I checked mine after an hour drive and found 94 degrees, felt little to no heat. Most everything under the truck that wasn't exhaust, or gears was about the same. It's almost 90 here in Gawga today. Truck did sit for about 10 mins before I remembered to check it but the diff was at 120 and tranny at 150 to 160ish depending on were you checked.
Sorry about the lousy pic. My photog fu is not good
Time to break out the tools and scrape the knuckles. Hopefully it won't cost YOU much but chances are good we might get a new story
And don't believe it can't happen from something so simple as a carrier bearing change. This is Tugly we're talking about.
https://www.ford-trucks.com/forums/9...nt-w-pics.html
(please remember to chock the tires, that's not the kinda story I'm hoping for)
It's been in the 80s here, and the rest of the shaft shows ambient temperature. The carrier bearing was new in May... but I've dropped the drive line countless times without injury. Sorry guys, nothing notable there.
Yes... the two halves are synchronized, marked, and spun-balanced as a whole.
Update: I have taken a mechanic and the driveline guy for test drives, and of course - Stinky was on his best behavior during both drives. I can't get input on something that won't show up with the pros in the seat. While there is a strong vibration that comes and goes on a whim, there is a subtle one that has the frequency of a driveline. Others who ride in Stinky feel "it's a truck, what do you expect?"... but he rode smoother than this last winter.
In my search for answers, I turned to the thermometer and found something I hadn't seen before. I may have to just let this go until I sort out the more serious intermittent vibration - which the parts are in transit.
Side note: While discussing this with the driveline guy, he was making "Why don't you get rid of the truck and..." jokes. He followed that phrase with "...get a real hobby", "...get a gasser", and "...get a Duramax". During the test drive, he said "Oooo.... what's that?" as he gestured to the tablet with Torque Pro running, and "This is a nice truck, I'd keep it".
Maybe it was the steering wheel that swayed him.
