Full Float Dana 60 Disk Brake Axle
Category: Drivetrain
Price: $500
Private or Vendor Listing: Private Listing
Part fits (you may select multiples): '06+ Civic/CSX, Prelude, Fit, S2000, CL, TL & Vigor, Motorcycles, Hybrids
Item Condition: WA
Engine: Part suitable for gas truck, Part suitable for diesel truck
This is a hard to find very heavy duty rear, 35 spline shafts, large thick tubes, cast spring perches, dana 60 center, dana 70 full float outers, disk brake with large dual piston calipers, mini drum E-brake, U-joint flange, correct SRW width and 8x6.5" lug pattern, includes lines and cables.
Has 3.55 ratio. Has very recently had new Rotors and Pads installed.
Wheel Mount Surface to Wheel Mount Surface (WMS) is 67.5" and the current Spring perch center width is 49". At the widest point outside of hub to outside of hub is 75.5"
I guarantee can not find a better factory 60 period! Unlike every aftermarket disk conversion I've seen you don't loose your parking brake and it has DUAL piston calipers.
I will not ship this axle as this is very heavy.
Delivery is possible in Washington state or to the Portland Or. area for a reasonable rate.
This is a great axle for swaps, I have put one in my 78 CCSB and love it.
bubbas78f250
67
01-08-2023 12:31 PM
roshan
09-04-2013 12:45 AM
Franken-Truck
08-13-2005 09:33 PM
