Before I go getting dirty all over again... Transmission cooler line?
Just completed swapping the lower radiator hose and I think I banged against the line just above it. It had been dripping before hand and I think that explains why the hose was so swollen but now with the new oil its dripping like a faucet that hasnt been fully shut.
It is leaking just after the fixture/screwy part (sorry for newb lingo) where it meets the actual steel hose
Im guessing this is as easy as attaching a new line... but I am not finding a replacement at Advance Auto/Napa/Pep boys that resembles this under transmission cooler line. Is this called something else or am I just mildly retarded? It appears that there are metal nipples that screw in now and u clamp on rubber hoses, correct me if I am wrong please.
One the plus side (knock on wood) the oil pan gasket I changed without lifting the engine isn't leaking a drop (yet)
I just replaced mine on my 97 f250hd a few weeks ago, i made my own out of nickel copper line and re used the fittings going into the radiator. It's not hard at all to do. I used NiCu line because its a plow truck and rusting lines is a problem. The one thing i did different was have the local hydraulic shop make me a 6" line so i could put it in the pressure line as a vibration isolator.
randomguy
07-20-2013 05:14 PM
