Go Back   Ford Truck Enthusiasts Forums > Diesel > 1994.5 - 1997 7.3L Power Stroke Diesel
Sign in using an external account
Register Forgot Password?
1994.5 - 1997 7.3L Power Stroke Diesel SPONSORED BY:
Welcome to Ford-Trucks Forums!
Welcome to Ford-Trucks.com.
You are currently viewing our forums as a guest, which gives you limited access to view most discussions and access our other features. By joining our community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join the Ford-Trucks Forums community today!
Old 09-08-2014, 02:12 PM
OldWoodsDiesel's Avatar
OldWoodsDiesel OldWoodsDiesel is offline
OldWoodsDiesel is gaining momentum as a positive member of FTE.
My 97 F-350 Rebuild/Repaint Thread
I currently have several other "rebuild" threads open, so why not start another one?
in truth, i'm out of shielding gas on my welder, so my T4 up-pipe fab is on hold and that's the last major step on the engine rebuild.
...so, i tore into the truck itself this weekend and made it deeper into both ends than i expected to in one weekend by myself.
The plan for the whole project is:
1. Get everything down to a bare rolling frame, blast it clean and paint the whole frame.
2. Gut the cab down to the dash – doors off, windshields out (they’re both busted now anyway), headliner, seats and floor out.
3. Paint everything! the inside of the bed, cab floor, grill, bumpers, and everything below the bend in the bodyline all around the truck will get Al’s bedliner. Then, rat-rod flat black goes on top of that an everything else. She’ll be all black in the end
4. Add overhead console to cab with gauges and lots of switches
5. Add LOTS of lights to the outside of the truck - or at least wiring for lots of lights to be added once i get the bumpers and headache rack made.
6. Oh yeah, and she’ll get that new 400-500 hp I’m buiding.
So, here’s the “before,” as it sat parked in front of the barn for a month after inspection expired at the end of July:
Click the image to open in full size.
I’ll be curious to see how much taller my son is next to it when its done  maybe I’ll put a lift kit on it to hide all the delays! On a side note, the truck fired right up after a month of sitting untouched. I was quite impressed with that old 360k mile engine. Almost [ALMOST] made me not want to rip her up. …halting the growing body rust is the main motivation for the project though. …that and more engine power!
I yanked the bed off on Friday night:
I wound up crunching the front left corner of it while lifting with straps, which sucked, but the wheel wells are all rusted out anyway, so at least I learned to be more careful with the good bed when I swap it over. I also came up with a method to remove the bed completely from above without having to drop the fuel tanks and mess with the rusty nuts below. I’ll post a separate thread and link it here shortly.
After removing the bed and driving the half-naked truck up to the house to annoy my wife, I tore into the front end. here’s a view of the core support:
Rusty in the corners, but the mounts are still intact unlike the 96 250 with half the miles on it that I parted out last year. I have some questions on this, but I’ll list them all at the end.
Here’s how she sits after a weekend of disassembly and plastic baggy labelling…
Notice my other little helper next to the red rolling toolbox?
Also – I started mocking up the IC on the front end as I’d like to get all the cutting and drilling done now prior to the full paint job. I moved the bottom of the AC evaporator back and cut for the inlet/outlet of the IC. I’m working on the mounts this week at work.
And here’s what the outside of the barn looks like now – my wife is going to be pissed!!!
Ok, now for questions for you all:
1. What the heck is that wire harness to nowhere under the driver’s side headlight opening on the core support. I don’t remember that on my 96 F250?
2. When adding an IC to our trucks, do you (who have done it) mod that center strap and run it up around the front of the IC, or do you just lose it altogether? I can’t see how it would work between the IC and the AC evaporator.
__________________
JP
96 F250 SCLB 4x4 7.3L PSD - RED (RIP - the part out has begun)
97 F350 CCLB 4x4 7.3L PSD - WHITE (361k mi - DD, auto->ZF5, 3.55LS, 6637, 3"DP->StraightPipe, 33x12.5x16.5's, object of more upgrades)
97 F250 RCLB 2WD 5.8L gas - BLUE (ZF5, 3.55, distant-future-project-truck - 235k mi)
Old 09-08-2014, 02:19 PM
nossliw's Avatar
nossliw nossliw is offline
nossliw is starting off with a positive reputation.
Not sure if it matters being a stick or auto, I pressed mine flat, I have seen others ditch it completely.
__________________
96 F250 CCSB 460, E40D, 3:55's, in the works 24 Cummins swap/compounds. Dads fun truck
97 SCLB 7.3 PSD ZF5, 4:10'S, DP tuner, 6637, 4" Diamond Eye straight pipe, EBPV delete, CCV delete, 3" plenums w/ 6.0 IC/Rosewood Stage 1/waterinjection /T500
Old 09-08-2014, 02:26 PM
well, i'm stick as well, so no trans cooler for me so i can essentially put the IC right up against the evaporator. did you leave your trans cooler in the stock location and put the IC in front? didnt look like there'd be room enough for that.
and by "flat" do you mean, like a pancake, removing the u-shape to it, or just straightening it out so it didnt bow forward anymore?
also, do you cut that little stand off the back side of the black plastic nose/grill support? i'll try to get a picture of that if that description doesnt make sense....
__________________
JP
Old 09-08-2014, 02:31 PM
DIYMechanic's Avatar
DIYMechanic DIYMechanic is offline
DIYMechanic is a name known to allDIYMechanic is a name known to allDIYMechanic is a name known to allDIYMechanic is a name known to allDIYMechanic is a name known to allDIYMechanic is a name known to all
The answer to question umber one is Daytime Running Lamps. The DRL module plugs in there and gets mounted to the core support.
Looks good, keep up the good work.
__________________
--Nate "Just a redneck geek"
1997 F-350 7.3 PSD, 4x4, CCLB SRW, 3.55's, ZF5
If it isn't under warranty, I'll fix it myself.
Old 09-08-2014, 02:32 PM
nossliw's Avatar
Quote:
and by "flat" do you mean, like a pancake, removing the u-shape to it, or just straightening it out so it didn't bow forward anymore?
Well we both have sticks then...that being said it all depends how close you mount the IC. Flat as in I removed the bow. I used a 6.0 IC and it fit in there without issue.
__________________
Old 09-08-2014, 03:18 PM
thanks! and DRL's were just a Canadian thing at the time, right? what is the "module"? just a photosensor?
Quote:
i'll be running a 6.0 IC as well. thanks for the info. i'll have to look at it closer to night and choose a direction.
always nice to know what someone else has done (successfully or not :-)), though!
__________________
JP
Old 09-08-2014, 05:15 PM
427 fordman's Avatar
427 fordman 427 fordman is offline
427 fordman has a great reputation on FTE.427 fordman has a great reputation on FTE.427 fordman has a great reputation on FTE.427 fordman has a great reputation on FTE.
Looking good JP! I cut that center strap out completely.
__________________
Darin 99 ranger 76F250 66 fairlane
"TheBeast"1997F2504x4dually4.10's,160k,140VIDM,HPX ,4-5"dp, S366 turbo, 6637, elec. fuel,rosewood stage ones,php,arp studs, comp springs, smith brothers push rods, T500 HPOP,melling lpop,180 tstat,6.0 fan and IC,trucool,coolant filter,scan gauge,lots of other gauges,racer x valve body and billet converter, upgraded trans, F550 leaf springs,SD dual tensioner upgrade, cold ac mod
Old 09-08-2014, 08:02 PM
stainlessstroker95's Avatar
stainlessstroker95 stainlessstroker95 is online now
stainlessstroker95 is gaining momentum as a positive member of FTE.stainlessstroker95 is gaining momentum as a positive member of FTE.
I think we just straitend out the bow also. Progress looks really good!
__________________
Gabe 95 f250 4x4 super cab psd, zf 5 speed, 6637 air intake, scan gauge, stancor gpr, ccv mod, 140v IDM, HPX line, irate t4 mount, s366 turbo, i/c, 3" plenums, Rosewood 238/80 hybrids, T500, studs, springs, rods, DP Tuner f6 chip, diamond eye ss 4" exhaust, 3" dp, irate e fuel, short throw shifter, Valair kevlar/ceramic clutch, Destination MTs, d60 RSK V codes , shackle flip B codes, bilstien shocks, scorpion bed liner, custom tailgate. 96 f350 4x4 psd, dually flatbed welding truck, zf 5 speed, stock. 79 bronco.
Old 09-08-2014, 08:28 PM
No photocell on this one. The DRLs came on with the ignition, ran at a lower output than the low beam headlights and only shut off when you set the parking brake. I thought they were only on the Canuk trucks as well, but my old (green/white) truck had them. That's why I called it Bullwinkle. Big, Canadian, and kinda slow, lol. This is a bad picture but you get the idea.
__________________
Old 09-09-2014, 05:48 AM
thanks guys - yeah, this disassembly stuff is easy when the rust isn't too bad!
and that's 2 votes for straightening that center strap and one for running without it. I think i'll prob straighten it, redrill the hole, paint everything up, then if it doesn't fit, just throw it in the scrap pile... :-)
and good picture nate. I stared at that for about 10 minutes last night before I noticed the little dongle (I just wanted to say dongle) on the end of that harness. now I get it! but why put it all the way up there? there's plenty of room under the dash. weird.
__________________
JP
Old 09-09-2014, 06:12 AM
The only reason I know of JP is that "the dongle" must make a decent amount of heat. It had a pretty decent size aluminum heat sink on it.
__________________
Old 09-09-2014, 08:31 PM
Makes sense.
...dongle. :-)
__________________
JP
Old 09-09-2014, 09:18 PM
martin72's Avatar
martin72 martin72 is offline
martin72 has a great reputation on FTE.martin72 has a great reputation on FTE.martin72 has a great reputation on FTE.martin72 has a great reputation on FTE.martin72 has a great reputation on FTE.
Looks good JP.
__________________
Kevin
Mistress 1994 f350 CCLB DRW 7.3 Power stroke ZF5 4x4,TS 6 Position Chip, 6637 filter,Rancho RS 5000 shocks,
5" diamond eye exhaust
Old 09-10-2014, 08:55 AM
oldbird1965's Avatar
oldbird1965 oldbird1965 is offline
oldbird1965 is a name known to alloldbird1965 is a name known to alloldbird1965 is a name known to alloldbird1965 is a name known to alloldbird1965 is a name known to alloldbird1965 is a name known to all
Looks good JP, and good luck with the wife, LOL
__________________
Glenn
The Mule-96 2WD F250 EC/LB auto, Lots of Mods!! Semi retired, still runs great after years of pulling!!
The Mare 97 dually cc, s366 turbo, stage II's, IC, studs, springs, rods, JW auto, 4:10 LS, efuel, FS2500 bypass oil filter, HVHF IDM, IH WP, 6.0 trans cooler & rad fan, MBRP 4", SD tensioner, AFE, 220 amp alt, 38G tank, soundproofed, 3 different TS chips
Old 09-10-2014, 06:59 PM
Quote:
ha! she hasnt seen the mess, but she was just looking over my shoulder when i was reading your comment and is now on to me!!!
luckily she is very reasonable and lets me get away with this sort of thing on a regular basis.
in truck news, i got my upper IC mounts made at work, so i'm ready for some more tear down work this weekend and some more IC fitup.
hopefully i get the cab off, engine and tranny out and start prepping for blasting the frame.
one question for you all - how bad is the steering gear to change on a truck that is fully assembled? i plan to replace it, but i wont be touching the suspensions/steering on this rebuild and hope to do an RSK next summer. it'd make more sense to do the drop pitman arm on the new steering gear right away, as long as i'm not making [much] more work for myself on the install and removal than if i were to do it now.
any opinions?
__________________
JP
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Similar Threads
An Engine Rebuild/Refresh Thread OldWoodsDiesel 1994.5 - 1997 7.3L Power Stroke Diesel 121 10-17-2014 06:09 AM
My quick and dirty bed removal technique OldWoodsDiesel 1994.5 - 1997 7.3L Power Stroke Diesel 7 09-15-2014 07:09 AM
7" Headrest Monitor Install sessland Excursion - King of SUVs 20 09-10-2014 05:04 PM
what is all this red stuff?? maxtruck00 6.0L Power Stroke Diesel 6 07-22-2014 08:46 PM
Everything look alright down there (rust, leaks)? loudoun 1999 - 2003 7.3L Power Stroke Diesel 3 07-16-2014 12:22 AM
Powered by vBulletin® Version 3.8.7 AC1
Copyright ©2000 - 2014, Jelsoft Enterprises Ltd.
Advertising - Terms of Use - Privacy Statement - Jobs
vbulletin Admin Backup
