My 97 F-350 Rebuild/Repaint Thread
#181
Ok, maybe I WILL run one. Sounds like it may be needed after all! Thanks for the additional input guys.
Too bad they don't just make a higher psi-rated map sensor that'll work on our trucks. Seems weird to intentionally mislead a sensor that directly contributes to fueling rates in high power situations. I guess the various tuner programs are just set up to keep increasing fuel with increasing pedal, and rpm once over a certain boost level?
#182
#183
I did put it back on today. The map side of the boost fooler I connected to my coolingmist control that operates on boost. The IC pipe side of the boost fooler I connected to my boost gauge. The boost gauge acted normal but the map side of the boost controller only showed 18 psi boost max. I guess it works, I'll leave it on for awhile and see if it pulls any better. The boost fooler is center left in the picture.
#184
Looks like youve got some ports on that baby! Mines just a simple one from the plenum to the map w a pressure regulator that comes pre-set...
https://www.strictlydiesel.com/p-267...nihilator.aspx
#187
This is where I got mine. Down near the bottom it talks about compressor regulators.
http://www.dieselsite.com/boostreliefvalve.aspx
#188
#189
#191
ok, boost fooler it is, then! now to decide which one... looks like they're the same price.
now on to the next question - i am starting to work on my doors and went to take the power doors off of my parts cab. the passenger door came off no problem, and i found that the one connector on the driver door that was common to my non-power door was right where i expected it to be. i did not locate a connector for the other thicker harness... does the power driver door harness really go all the over to the passenger side behind the dash with no connector in between? it sure looks that way!
#192
So all u gotta do is set it yourself w your air comp...
#194
Hindsight is always 20/20 but knowing your a wrencher you can just go down to napa, lowes, home depot and get a psi regulator, 3/8nptx1/4" hose barb fittings and hose and whip it up yourself.. Maybe you could even find a little 90 degree bracket.. Iirc my fooler comes set @ 22 psi.. I forget what overboost is 26 27ish?
...and yeah, me too :-( oh well, i'm good at taking dashes out now anyway!
