2003 E350 6.8 PCV line elbow
Just a bit of patience, strong hands and of course replacement parts in hand before beginning. Dorman makes a nice replacement elbow:
If the hose from the PCV to the elbow is in bad shape it can be replaced with almost anything that fits but is also intended for automotive use.
While you're at this double-check the valve cover grommet---it should be available separately too if its bad. I'd use just a dab of dielectric grease around the insert portion to keep it soft and supple, effecting a better seal.
HTH
HTH
1972-34ton
22
03-28-2023 08:17 PM
b4hntn
1978 - 1996 Big Bronco
21
10-09-2018 03:53 PM
