Rear Glass Purchaser
Old 09-06-2014, 09:50 PM
gysgtbigdaddy's Avatar
gysgtbigdaddy
gysgtbigdaddy is offline
Does anyone know where I might be able to purchase a rear window for my 53 F100? LMC sent me the small window and doesn't sell the style I need. MMy truck needs the large flat window. I believe its 52" long or close to that. My local shops are of no help either.
Old 09-06-2014, 10:18 PM
larryb346's Avatar
larryb346
larryb346 is offline
I bought a rear window from LMC for my 55. It was about 1/2 inch too small all the way around.
Good Luck
Old 09-07-2014, 03:10 AM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
Why buy glass from a repop seller and pay shipping charges when it's available from any auto glass shop. Since the back glass is flat, it can be "cut-to-fit" from glass stock.
Excepting panel trucks & P Series Parcel Delivery, the back glass is the same for all 1953/55's and 1956's without wrap around window.
Old 09-07-2014, 06:35 AM
teardropty's Avatar
teardropty
teardropty is offline
Unless someone did a big window conversion or otherwise modified it, there was only one size rear glass on the 53 F100 standard from the factory. Remember the rubber seal takes up some room and the rear glass is installed from the inside to the outside.
Old 09-07-2014, 09:35 AM
carnut122's Avatar
carnut122
carnut122 is offline
Mine was "custom cut" as it still had a lot of rough edges. It went back in(shrug), so it'll stay in as long as it lasts.
Old 09-07-2014, 10:16 AM
Doc's Avatar
Doc
Doc is offline
I'll tell you exactly why I will never bother with a local glass cutter with my truck again. I tried a local cutter. He charged me much more than what LMC charges, including shipping. I called around to a few other ones. All of their estimates were the same as the original guy. Plus, when you factor in the time, gas, and aggravation of dealing with the public, it's much cheaper to just order it and have it sitting on your front porch in about 2 or 3 days packed nicely in a foam-filled box.
Old 09-07-2014, 10:29 AM
gerrymoe's Avatar
gerrymoe
gerrymoe is offline
Old 09-07-2014, 10:55 AM
CharlieLed's Avatar
CharlieLed
CharlieLed is offline
I have a loose window sitting here, it measures 50 inches across at it's widest point. The corresponding cab opening measures 49-1/2 inches.
Old 09-07-2014, 12:02 PM
gysgtbigdaddy
Originally Posted by gerrymoe
Thanks Gerrymoe! Found it Glass - Mid Fifty F-100 Parts
This still has be wondering why LMC sent me a small window......even after I called they didn't have the correct window.
Old 09-07-2014, 12:42 PM
CharlieLed's Avatar
CharlieLed
Gunny,
I don't know where you are located in SoCal but if you are close to the Ontario/Pomona area there is a glass warehouse there that should have your glass and be able to sell it to you as a will-call. Shipping on glass is $$$.
Old 09-07-2014, 01:32 PM
gysgtbigdaddy
I'm in San Jacinto so not far...what is the name of the business? I'm all about saving some $$$!!!
Old 09-07-2014, 02:05 PM
CharlieLed's Avatar
CharlieLed
I bought glass from Bob's Classic Auto Glass out of Eurgene OR but picked it up at the warehouse in Ontario. Unfortunately I don't recall the name of the wholesaler...he is the one who supplies all the glass to the Overhaulin' show. I looked at Bob's site and did not see just the rear glass listed, you may give him a call and see what he has. Another option is to contact a local shop, I am in El Cajon and there are a few around here as well. If you need a template I can send you one.
Old 09-07-2014, 02:16 PM
gysgtbigdaddy
OK, I'll do some homework. From who I could contact local to cut it was $150 and that's with me providing the measurements and me installing it. Crazy
Old 09-07-2014, 05:35 PM
teardropty's Avatar
teardropty
Sorry but I still don't understand were you are getting a "big" window or "small" window from? 53-55 F100s all had the same size rear glass. Can you explain?
Old 09-07-2014, 11:20 PM
truckeemtnfords's Avatar
truckeemtnfords
truckeemtnfords is offline
It sounds like LMC's screw-up and they sent him the wrong glass. Don't get worked up over it, Charlie has him covered.
Quick Reply: Rear Glass Purchaser
