Rear Glass Purchaser
Why buy glass from a repop seller and pay shipping charges when it's available from any auto glass shop. Since the back glass is flat, it can be "cut-to-fit" from glass stock.
Excepting panel trucks & P Series Parcel Delivery, the back glass is the same for all 1953/55's and 1956's without wrap around window.
Unless someone did a big window conversion or otherwise modified it, there was only one size rear glass on the 53 F100 standard from the factory. Remember the rubber seal takes up some room and the rear glass is installed from the inside to the outside.
I'll tell you exactly why I will never bother with a local glass cutter with my truck again. I tried a local cutter. He charged me much more than what LMC charges, including shipping. I called around to a few other ones. All of their estimates were the same as the original guy. Plus, when you factor in the time, gas, and aggravation of dealing with the public, it's much cheaper to just order it and have it sitting on your front porch in about 2 or 3 days packed nicely in a foam-filled box.
This still has be wondering why LMC sent me a small window......even after I called they didn't have the correct window.
I bought glass from Bob's Classic Auto Glass out of Eurgene OR but picked it up at the warehouse in Ontario. Unfortunately I don't recall the name of the wholesaler...he is the one who supplies all the glass to the Overhaulin' show. I looked at Bob's site and did not see just the rear glass listed, you may give him a call and see what he has. Another option is to contact a local shop, I am in El Cajon and there are a few around here as well. If you need a template I can send you one.
