e-fuel pump installed still many cranks to get it started
Old 09-08-2014, 11:09 AM
Darrell Thompson's Avatar
Darrell Thompson
Darrell Thompson is offline
Originally Posted by speedwrench72
your gp system might look like it is functioning, But are the glows getting hot? one sure fire way to know is to plug the engine block heater in regardless of tempature out. over nite. and start it with out using GP's if it fires right up its not air.. its gp's
Is there another way to test GP i have Manual plugs and no block heater?
Can i plug a GP out plug it to harness wire press manual button and see if she Glows ?
Old 09-08-2014, 10:49 PM
zloetakoe's Avatar
zloetakoe
zloetakoe is offline
I replaced the GPs and put in a duralift, same as you. I wait about 15 seconds for the pump to do its thing, and attempt to fire it up. Works MUCH better than before. I was draining the batteries 2 times sometimes to get the dang thing to start. Now it's just 2 seconds or so and it fires up, i use manual GP for about 10-12 seconds.
Old 09-09-2014, 01:57 AM
Darrell Thompson
Are you seeing any air being pulled into your Duralift ?
Old 09-09-2014, 09:07 AM
Greg5OH's Avatar
Greg5OH
Greg5OH is offline
nic truck, love the bed!
Old 09-09-2014, 12:52 PM
jayro88's Avatar
jayro88
jayro88 is offline
I will double check, but I believe mine does have some air in the bowl while it is running. Mine had a hard start issue. The issue ended up being an IP/Injector issue. I replaced them and now mine fires off quickly, even with the high idle/cold advance sensor unplugged. It did this all winter and we had a lot of days where the high was below 0*F. Of course I did plug it in during the winter.
Old 09-09-2014, 03:09 PM
DieselRugger's Avatar
DieselRugger
DieselRugger is offline
From what I recall, the pick-up for this pump is at the bottom of the bowl, so no air gets in the system. I think mine has air in the same place. Used the e-pump to replace the original mechanical pump which could not stay primed.
I assume that you have wired it up so that while your glow plugs are warming up your e-pump is priming the engine. Once I hooked up this new e-pump and put on new electrical battery connections (mine were corroded and not able to get tight on the terminal posts) my F-350 has not had a problem firing right up.
I stopped using the block heater, but from time to time keep a trickle charger on it, since this is a 3rd vehicle that we don't drive too often.
Old 09-09-2014, 09:36 PM
wtroger's Avatar
wtroger
wtroger is offline
I let mine run until the wait to start light goes out. Fires off like a gasser. White smoke would say air incursion. Make sure your return lines and orings are good. And your GP's are good.
Old 09-10-2014, 11:53 AM
Darrell Thompson
Greg5OH here's how my bed mounts. couldnt figure out how to PM pic to you.
Old 09-10-2014, 12:11 PM
Greg5OH's Avatar
Greg5OH
Greg5OH is offline
thank you sir! so you have a total of 3 cross braces bolted to the frame?
abe
11-09-2017 12:35 PM
ct50f1
20
02-17-2017 09:20 AM
Rovernut
10-15-2015 05:58 PM
lvin4jc
09-12-2011 11:45 AM
hollenjoe
Modular V8 (4.6L, 5.4L)
05-06-2011 02:03 PM
Quick Reply: e-fuel pump installed still many cranks to get it started
