My First AOD
Old 09-10-2014, 08:13 PM
TireDood's Avatar
TireDood
TireDood is offline
X2 in the pics request. I am also not far from attempting to rebuild mine. Bought it used, was fine for about 300 miles , then started slipping in OD. I talked to the guys at Baumann a couple of weeks ago, they gave me some good advice. I'll try to find my notes and post them....
Old 09-10-2014, 08:23 PM
TonyB55's Avatar
TonyB55
TonyB55 is offline
Originally Posted by ChuckRob
Welded up a holding fixture this morning, thanks TonyB55 for the design, I guess that I am ready to tear into this thing.
You're welcome, Chuck. It makes it a lot easier than trying to wrestle it on the floor. Nice job!
Old 09-25-2014, 09:42 AM
ChuckRob's Avatar
ChuckRob
ChuckRob is offline
Started to make a little progress with the AOD rebuild. I was tired of the truck being down so a found a used AOD that was in good shape and put it in. The truck is now up and running so I have plenty of time to spend on the rebuild. When I started to take the AOD apart the pan was full of band material and the oil was discolored. It was easy to determine that things were getting to hot. To remedy some of the heat I installed a B&M transmission cooler, in series and after the cooler in the Superior radiator.
We have the old transmission apart, the overdrive band was toast but no other apparent failures. I was suprised how easy it was to get the transmission apart, no special tools required except some snap ring pliers and a small slide hammer to pull the pump. Some pictures to follow this afternoon.
Old 09-25-2014, 11:20 AM
raytasch's Avatar
raytasch
raytasch is online now
Believe Nothing
Not to this most interesting thread but isn't this a result of a mis adjusted TV cable? Perhaps a tranny expert will weigh in.
Old 09-25-2014, 04:52 PM
ChuckRob's Avatar
ChuckRob
ChuckRob is offline
I don't think so, TV pressures were right on the money. I believe the problem was a high stall converter which builds lot of heat and not enough cooler.
daltonjamesadams
02-27-2018 03:51 AM
fatfenders56
07-09-2015 07:59 AM
THE BLUE HEAP
06-24-2013 02:31 PM
woodly1069
01-30-2008 08:04 AM
bigwheelin
01-17-2006 09:45 PM
Quick Reply: My First AOD
