pitman arm installation
Hi,
Just installed my freshly rebuilt steering box (thanks Rock Auto) in my '50 F1. I noticed the pitman arm and the sector shaft on the box are splined with a sort of keyway. I have centered the steering wheel and the front wheels and noticed the keyways don't line up. I don't think they were aligned when I disassembled them and the key in the pitman arm seems to be flush with the surrounding splines. Sure would appreciate any suggestions.
Thanks,
Tony (olguy)
Thanks,
Tony (olguy)
I only have one keyway in the arm and one in the sector gear. They don't appar to even contact one another. If I aligned the two, the arm would not be pointing straight down with the wheels centered. With no adjustmnt on the drag link it seems that positioning the pitman arm on the sector shaft must be done with the steering wheel centered and tthe left front wheel pointed virtually dead ahead. Am I wrong?
olguy
olguy
Ok I am not familiar with the 50 steerinbox just the 53-56. But if you disconnect the pitman arm and turn the steering wheel to the stop (right) and then turn it to the stop (left) and then back down half of it there you should have the keyway lining up with the pitman pointing down. If then the steeringwheel is of, I guess you haveto take off the wheel and move it.
If the keyway is not lining up with the pitman pointing down, I would guess the box is assembled wrong???
Pitman arm installation
Hi guys,
As the original poster of the thread, I'm going to admit that I didn't wipe off the grease, get down on my knees and look very closely at the whole mess. I took the pitman arm off the drag link and found that I had burred the splines enough that it wouldn't slip on. A needle file solved that and the arm slid on...Now it looks like the drag link may be a bit too long to have the left front wheel point straight ahead. I'll save that one until it's installed properly and isn't right. Oh, incidentally under the grease and after scoping it out closely with my bifocals, I found that both the sector shaft and the pitman arm have four keys....you guys were right...
Thanks to all involved,
olguy
olguy
How could the drag link be too long unless it is assembled improperly, it is a fixed length. Make sure the pitman arm is vertical and the parts in the ends of the drag link are installed in the correct order. I don't know about the F series, but on the 53-56 the parts DO NOT go in in the same order in both ends of the drag link, I would assume yours is the same way. The truck used the same parts and steered properly for 65 years, the parts didn't suddenly and magically change, you did something wrong. Admit it, take it all apart and clean it all so you can see what you are doing (should always be the first step when doing any mechanical work), inspect the parts for wear (especially the ***** on the pitman arm and steering arm on the spindle, if they show any wear replace them along with the cups in the drag link), get a shop manual and check that you are putting each and every part back together properly, DON'T assume ANYTHING! Steering is too critical to safety to work on haphazardly.
