Replacement Glow Plug Relay
Anyone have a suggestion for a replacement GPR for a '90 non-turbo 7.3 IDI? I've got 3 plugs that won't come out and I don't have the money to remove them at this time. Currently have them unplugged, but GPR doesn't work without all 8 plugged in as is my understanding. Wanted to know if there is an aftermarket GPR I could use until I can get the 3 plugs removed that will power the remaining 5. Something that supplies power momentarily using the ignition switch instead of adding a momentary switch.
on
The GPR doesn't stop the power going to the glowplugs, the glow plug controller does that, it protects the other glowplugs from getting to much juice. you can take any wire with 12 volts and hook it up to your existing GPR, or run a wire to a push button, so you dont forget and leave them on. Get some PB Blaster, the best lube on the market, people are coming around to it now. Blows WD-40 and all the other crap away. Soak them glowplugs overnight and they will come right out in the morning.
So you're saying bypass the controller and just add a momentary switch? Is there a way to add an inline momentary switch so I can still use the ignition?
I accidentally crossed the poles on my batteries and fried the GPR, didn't fix it soon enough and the result was the controller melting down and leaving the plugs on, causing some of them to incinerate. I pulled one out and the tip was completely gone. The stuck glow plugs will rotate out, but the tips have been damaged to where I can't get them out without a lot of force. I'm afraid of dropping garbage into the cylinder by forcing them and I'm trying to avoid having to take the heads off to remove them.
Received 3,106 Likes
on
i hook the glow plug to a cordless drill. then spray PB Blaster down the hole and spin the plug with the drill while gently pulling up and pushing down. spray and repeat. i have never had one that did not come out after a few minutes.
the drill spinning cuts the carbon off the tip and you lift it .
The stuck plugs will unscrew, but then reach a point where they no longer move. I'm guessing the tips have swollen and are not allowing the plugs to come out. I'm afraid of forcing them out for fear of having debris fall into the cylinder and cause damage to either the cylinder walls, piston, or valve. A couple of them were completely blown when they were removed, which leads me to believe they did at some point leave debris to be ejected. Any insight?
Thank you!
Thank you!
Just to be clear, this all started after I accidentally crossed the battery poles when I needed to charge the batteries. After that, the wait to start light no longer came on. Since it was summer, I didn't immediately take care of it and after a 3 hour drive pulling a trailer in 90+ degree weather, the light came on and stayed on. I immediately pulled over when I realized, but the damage had been done. The GP Controller had melted down and was crackling and popping. Fortunately, I was across the street from an auto parts store and was able to get a replacement GPR and controller. It worked a couple times, then stopped working. I decided to pull the plugs and see if that helped and that's when I discovered the 3 that wouldn't come out along with a couple that had completely incinerated the tips off.
on
the drill and oil will help cut the carbon off the tips until the plug is able to come out of the hole.
the small amount cut off the tips will not be of any major concern, but if you really want to you can pull the injector and put a vacuum hose in the injector hole while blowing compressed air into the glow plug hole.
Thank you!
If the tip is swollen or exploded the tip will come off or the broken piece will fall into the cylinder. Then YOU HVAE TO PULL The head or the piston will pound the piece into the top of it
on
I would without a doubt do what Tom has said try the drill and PB trick, load it up and drill forward and reverse while pushing in and out ( ya I know HA HA) you might have a chance to get a couple out that way, you got the other 5 out right? The heads are last resort! You may have too but listen to Tom, he has been there and done it.
I will hope for ya!!
That being said, I pose the original question of this thread. Is there a temp solution I can employ to power the 5 remaining plugs with a momentary switch powering the relay and bypassing the controller? Is there a way to keep the 5 plugs from getting too much juice so I don't kill them as well?
on
in all the years i have been pulling stuck glow plugs with the drill method, i have only had one break a tip off, and i got that out through the injector hole with a small magnet.
all the others were cleaned up with the vacuum and compressed air method.
and that broken tip was on one of the first ones i did, because i was impatient and forced it.
Thank you Tom. You're confidence in your suggestion is inspiring. I'll keep you updated on how it turns out.
on
