Help! Stuck Distributor (4.9L)
I was trying to replace the lifter gallery gasket, so I removed the distributor cap. In doing so, I snapped off one of the bolts.
I am trying to remove the distributor so that I can try to remove the snapped bolt.
I got the bolt and clamp off. I can turn the distributor very easily. However, it refuses to budge when I pull up on it.
Is there some sort of trick to this? A clip or pin that needs to be removed? The Hayes manual says to simply pull up on the distributor.
The Ford manual says that #1 needs to be at TDC before pulling the distributor? I've never heard that needed to be done unless you forget to mark the rotor position and the distributor position. Do I need to put #1 at TDC in order to physically remove the distributor?
Thanks in advance.
Thanks in advance.
x2 ... theres nothing but friction holding it in. just remember that it is aluminum ... be persistent but not brutal.
Thanks folks!!!
I got the distributor off. I soaked it with Kroil for a day. I managed to slip a small putty knife in between the block and the distributor and gently pried it up. I switched to a small flatblade screwdriver once there was enough of a gap.
It came out in one piece with out too many nicks on the aluminum.
Do I need to change the o-ring after the Kroil soaking? I suspect I should.
I drilled out (most) of the remaining snapped bolt. I wasn't able to get it out with the reverse drill bit, so I just drilled it though. I'm going to enlarge the hole a bit and just use a longer screw, a lock washer, and a nut to secure the cap.
IDIDieselJohn
09-16-2012 07:29 PM
cbjr61
08-29-2005 08:23 PM
eandaauto
06-01-2004 11:17 PM
