96 - key turns but nothing happens, actuator? - Ford Truck Enthusiasts Forums
1978 - 1996 Big Bronco SPONSORED BY:
Old 09-04-2014, 06:05 PM
96Broncowner 96Broncowner is offline
96Broncowner is starting off with a positive reputation.
My 96 bronco has the old key turns and nothing happens issue. My first thought is the actuator but after doing some searching it seems to be less likely an issue with the 96 than the older models. I have just removed the steering wheel and am stuck. There is a white plastic cover with a yellow tab that covers access to the rest of the column. Has anybody removed this and if so does it take a special tool? It shows all the symptoms of a broken actuator. Key turns with little to no resistance, it will not shut off even with the key removed, and will not engage the starter when turned fully on. I have replaced two actuators before but they were on an 87 and 91 column. the newer style has me stumped.
96 5.8 auto Eddie Bauer
Old 09-04-2014, 06:34 PM
Figured out the white plastic piece, two tabs and loosen the airbag wires. Now I am out of ideas. It looks like ford ditched the old pot metal actuator (thank GOD) for a plastic one that slides when the key is turned. I will try to remove this and inspect it for damage but am open to any suggestions on where to go from here.
Ignition Actuator removal for 1989 F250 davidarcangel 1987 - 1996 F150 & Larger F-Series Trucks 1 05-25-2016 06:07 PM
p2006 and pulling my hair out BRay09 2004 - 2008 F150 2 10-02-2015 08:05 PM
Ignition Key Switch Question TNCritter 1987 - 1996 F150 & Larger F-Series Trucks 4 01-09-2015 05:51 PM
In over my head! Steering issues...sigh bradsblue89 1987 - 1996 F150 & Larger F-Series Trucks 11 08-25-2014 01:14 PM
2003 F150 Broken Ignition: Work Around? Ranger Gord 1997 - 2003 F150 1 12-09-2012 06:13 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
