1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Clutch fan
Old 09-04-2014, 04:51 PM
Spkrvr's Avatar
Spkrvr
Spkrvr is offline
Clutch fan
I have a 2001 f250 with a 7.3. Can anyone explain the operation of the clutch fans on these trucks. Sometimes when pulling my camper and the truck downshifts it will roar like a sob. Other times I will hear it but like it is an electric fan. Then there are times you hear it and then the noise goes away. Can this fan be heat operated. Any advice would be appreciated. Micky
Old 09-04-2014, 04:58 PM
David7.3's Avatar
David7.3
David7.3 is offline
Thats the whole idea of the clutch fan, it has a temperture spring on the front of the fan and as it heats up the spring winds up and tightens the clutch allowing the fan to turn maximum. that why you here the roar after a long drive with the a/c on or just the heat coming off the radiator, then it disengages and runs normal.
Old 09-04-2014, 08:42 PM
Pit Crew's Avatar
Pit Crew
Pit Crew is offline
My new 2014 roars on cold start ups, It sometimes runs for ten miles or so I hate it. I found that if I put tha peddal to the floor for 5 seconds or so it stops. Dosent do it all the time, but most of the time. Shouldnt it only run if its hot?
Old 09-05-2014, 08:38 AM
Spkrvr's Avatar
Spkrvr
Spkrvr is offline
Thanks that makes sense
Ritory
11-22-2010 04:02 PM
bdrummonds
10-14-2007 03:30 PM
tjay460
08-01-2006 12:52 AM
Ford1TonsRock
10-14-2004 11:01 AM
tmcalavy
09-18-2001 12:04 AM
Quick Reply: Clutch fan
