Help Installing Wooden Bed - 1950 F1 - Ford Truck Enthusiasts Forums
Old 09-04-2014, 04:02 PM
nigeljoiner nigeljoiner is offline
nigeljoiner is starting off with a positive reputation.
After cutting down the wooden slats for the truck bed I've come to see that the installation of the wood is interfering with hump in the frame at the rear wheel. Am I correct that the wood installs directly to the frame as you see in my photos, or does the wooden bed need to be raised above these humps?
Does anyone have experience in installing a wooden bed in a 1950 F1?
Does the wood attach directly to the frame?
Is there a riser kit that raises the wood higher off the frame?
Thanks for your help. The project has come to a stop until I can figure this out.
My photos ( Truck - Imgur )
If this helps helps anyone out i found a similar project with photos but I can't seem to figure out what they have done ( http://www.ford-trucks.com/forums/12...0-f-1-a-2.html
Old 09-04-2014, 04:11 PM
52 Merc's Avatar
52 Merc 52 Merc is offline
52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of
Welcome to the forum. Which bed are you using on your '50? The early or late style? Either way, you should have either a framework that the bed is assembled to, in the case of the early style, or crossmembers across the framerails that the wood and bedsides attach to with the later style bed.
Old 09-04-2014, 04:24 PM
This would be the later style. You can see in my photos the wood is sitting directly on the crossmembers, however by doing so, the wood falls flush with the framerails, but not entirely flush due to the rear wheel hump.
Should the wood be sitting on directly on the crossmember or higher to be raised over the hump?
Old 09-04-2014, 05:32 PM
Wayne Waldrep's Avatar
Wayne Waldrep Wayne Waldrep is offline
Wayne Waldrep has a very good reputation on FTE.Wayne Waldrep has a very good reputation on FTE.Wayne Waldrep has a very good reputation on FTE.Wayne Waldrep has a very good reputation on FTE.
I looked at your pics. Notice your cross members compared to the truck you posted in your link. Mine are like his in the pics...yours are upside down compared to mine and his. When I put my wood bed in there are cross pieces that fit down into those cross members and then the wood sits on that. Mine and his may be the ones that are upside down for all I know. But I had no problem making it work that way. I have no pics of the wood risers in the cross members but you can see how they would sit down in mine compared to yours that have no "U" facing up....yours faces down.????
bedwood
Old 09-04-2014, 05:34 PM
yamagrant's Avatar
yamagrant yamagrant is offline
yamagrant has a superb reputationyamagrant has a superb reputationyamagrant has a superb reputationyamagrant has a superb reputationyamagrant has a superb reputationyamagrant has a superb reputationyamagrant has a superb reputationyamagrant has a superb reputationyamagrant has a superb reputationyamagrant has a superb reputationyamagrant has a superb reputation
Don't those cross member's sit on top of the frame?
Old 09-04-2014, 05:42 PM
yamagrant's Avatar
Wayne you type a lot faster than me.
Old 09-04-2014, 05:45 PM
Quote:
Pffftt....I started typing an hour before he even started this thread!!!
And yes they go on top and flipped over.
Old 09-04-2014, 06:23 PM
SORRY!!!!!!!!!!!! Welcome to FTE!
Old 09-04-2014, 07:03 PM
69 f-100 aman 69 f-100 aman is offline
69 f-100 aman is new and has a neutral reputation at this point.
Quote:
bedwood
what kind of wood did you use in your bed.I like the way it looks
Old 09-04-2014, 07:28 PM
ChuckRob's Avatar
ChuckRob ChuckRob is offline
ChuckRob has a great reputation on FTE.ChuckRob has a great reputation on FTE.ChuckRob has a great reputation on FTE.ChuckRob has a great reputation on FTE.ChuckRob has a great reputation on FTE.
Old 09-04-2014, 08:31 PM
Quote:
Thanks! I ordered "clear" pine from Lowe's because I like the lighter look. All I put on it is many many coats of marine spar varnish.
Old 09-04-2014, 10:35 PM
ben73058's Avatar
ben73058 ben73058 is offline
ben73058 has a great reputation on FTE.ben73058 has a great reputation on FTE.ben73058 has a great reputation on FTE.ben73058 has a great reputation on FTE.ben73058 has a great reputation on FTE.
Hey Nigel,
Welcome Aboard! Keep asking questions - someone here should be able to help out. Here are some pics from our '50 bed "reconstruction". We had to replace most of the support structure for the bed so it's not exactly stock.
Hopefully this helps some.
Looking good up there in Canada!
Ben in Austin
1950 F1
Old 09-05-2014, 05:52 AM
Thanks was there a store parts # on the wood, I think Im going that route with mine also......
Old 09-05-2014, 09:39 AM
Skalywag Skalywag is offline
Skalywag is gaining momentum as a positive member of FTE.
I haven't put the wood in my bed yet, but it looks like Chucks kit would be the best way to get around the kick up on the bed frame. The early and late 50 bed must be a lot different.
Old 09-05-2014, 11:51 AM
So from what I see there is quite the differences between years in how this is done. I find this restoration to be the closest to my problem, as the frame matches what I have exactly.
As you see from this photo the largest arrow points to the same hump in the frame which I am trying to work around. The wooden piece he has sitting on this frame sits cleanly across the back of the box, but would need to be cut around this hump as the bed is installed.
Here in his finished bed, you see no cut outs around this hump, which leads me to believe that the bed is sitting on perhaps wooden strips. Therefore the strips are bolted to the frame and the bedwood is bolted to the strips.
What are people's thoughts on this interpretation?
F2 Express Bed Wood Installation Cougar54 1948 - 1956 F1, F100 & Larger F-Series Trucks 11 07-05-2016 12:01 AM
1967 F100 4x4 - Flatbed Conversion (Video) Mister_King 1967 - 1972 F-100 & Larger F-Series Trucks 20 03-20-2015 12:58 PM
Ford Trucks in the Woods jcmiller97219 1948 - 1956 F1, F100 & Larger F-Series Trucks 43 02-02-2015 03:22 PM
Flareside: bed to frame mount blocks nikmish 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 3 02-14-2013 02:23 PM
Wooden Bed And Bed Sides TBSS110 1948 - 1956 F1, F100 & Larger F-Series Trucks 8 03-21-2011 04:18 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
