1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
OEM emblem cam install questions
Old 09-04-2014, 10:09 AM
kengarchow's Avatar
kengarchow
kengarchow is offline
i bought a factory emblem cam to put on my 2013 tailgate and use with my Edege CTS.
had a few install questions to clarify
how does original 9 inch ford emblem come off (i think just stuck on)
how does new camera attach
I'm going to add raa plug to 0em wiring so i can attach to my CTS monitor, what wires are for what on camera
thanks
Old 09-04-2014, 10:55 AM
hpwoee's Avatar
hpwoee
hpwoee is offline
There is some good info here
Use the search function
https://www.ford-trucks.com/forums/1...nd-camera.html
Old 09-04-2014, 12:43 PM
kengarchow's Avatar
kengarchow
thanks thats a start
thanks
i would have never thought to search under that title
that helps with the wiring
still not sure about the mounting procedure
Old 09-04-2014, 11:18 PM
kengarchow's Avatar
kengarchow
got rca and power hooked up to oem cam
now need to install camera
has anyone removed the 9 inch tailgate badge and installed the oem emblem cam?
if so hows it done?
thanks
Old 09-05-2014, 02:14 AM
Redrkt's Avatar
Redrkt
Redrkt is offline
I could be mistaken but I think you have to remove the inside of the tailgate to get to the pins that hold the emblem on, and they are held in place with spring clips I think
Old 09-05-2014, 10:16 AM
kengarchow's Avatar
kengarchow
tried that
took tail gate panel off and there was a metal baffle in the way of getting to the back of the emblem
any other ideas
thanks
Old 09-05-2014, 10:03 PM
kengarchow's Avatar
kengarchow
think i have it figured out out
looks like the inch non camera emblem is a stick on
to remove yo have to pry it off
back up camera option emblem has a housing that screws on the the tailgate behind the emblem that snaps on to it
bikerman5345
2017+ Super Duty
03-20-2017 08:25 PM
ssoundwave
2017+ Super Duty
11-12-2016 10:50 PM
kengarchow
06-25-2014 11:06 AM
debestuss
03-16-2005 03:51 PM
Quick Reply: OEM emblem cam install questions
