1983 F350 5L straight six with gas
VIN: 2FTHW35G9DCA79840
I've just bought a chilton ford manual and it shows G as it should have a V8 351M engine and its got a straight 6.
H = Class G Hydraulic Brakes, 8,501-9,000 lbs. Gross Vehicle Weight Rating.
W35 = F350 2WD Crew Cab Pickup.
G = 351W 2V (no 351M's after 1982).
9 = Check digit, FoMoCo usage only.
D = 1983.
C = Oakville Ontario Canada Truck Assembly Plant.
A79840 = 1983 Numerical Sequence of Assembly, the trucks specific serial number.
Yes, the radiator has to be changed, as the I6 has the outlets reversed from those on a V8.
The alt/PS pump/AC and air pump (if equipped) brackets are also greatly different for the V8, so you would need to find an engine that has all the needed brackets.
#29
Mark - Not sure where you got the # for the water pump, but it isn't correct, for two reasons. First, as the illustration below shows, the # for a water pump is 8501. Second, in the 80's there are no "AA" suffixes, as shown in the second and third pics.
On top of that, the thermostat "connector", which we usually call a "housing", is #8592 not 8594.
So, these pics should give you the info to find your own # as I don't know what engine you are working on since last I remember you were thinking about replacing the engine. Anyway, if you want to tell us what you are working on we can help. But wherever you are getting your numbers from is not correct.
As for acquisition, perhaps with the right #'s you can find them over there. Or, have them shipped to you.
#30
UPDATE - Chris/ctubutis, has gently pointed out to me the error of my ways. The #'s you gave may well be what is shown on the parts, and the confusion is around "engineering #", "casting #", and "part #". It is all very confusing, but let's just say that the "Part Number" column shown above is typically not the number shown on the part. And, people advertise parts based on what is shown on the part rather than what is in the parts catalog.
So, what does that mean? It means you can't always go search for the # shown on the part and find a hit. That's because the parts dealers typically go by the # in the parts catalog. But, as said, some people have NOS parts and go by the # on the part. That would seem to give you two approaches:
My apologies to Mark and thanks to Chris.
- # on part: Use the # on the part to find another one with the same #. Typically that'll be someone on ebay.
- Catalog #: Google the # from the catalog and you will usually find a number of parts dealers with the parts you desire.
