1997 lug pattern to 1993? - Ford Truck Enthusiasts Forums
Old 07-13-2003, 08:11 PM
spencry25 spencry25 is offline
spencry25 is starting off with a positive reputation.
I just bought some rims and tires from a 1997 F-150 with 16" rims, and they didn't match up to my 1993. I thought all 5 lug fords were the same? What stock set up can I use, and is there any difference between 2WD and 4WD lug patterns? Thanks.
Old 07-13-2003, 11:25 PM
dbeames's Avatar
dbeames dbeames is offline
dbeames is starting off with a positive reputation.
I think it was in 97 when they changed the lug pattern. They made it larger. 1997 was the year that Ford changed the
F-series/Bronco pairing to the F-series/Expedition pairing. So they made a lot of changes in that model year. You would have to get wheels prior to 97 to have them fit on your 93.
Old 07-14-2003, 01:53 AM
LxMan1's Avatar
LxMan1 LxMan1 is offline
LxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant future
Does anybody know the bolt pattern on the 97-up? I know it used to be 5 X 5 1/2".
Jimmy
Old 07-14-2003, 01:21 PM
dbeames's Avatar
LXMAN1,
Yeah from 1980 to 1996, the bolt pattern for bronco's and F150's was 5x5.5". Then Ford switched combo's to f-series/expedition and the pattern turned into 5x135mm. Why? I have no idea.
Old 07-14-2003, 03:13 PM
Racerguy's Avatar
Racerguy Racerguy is offline
Racerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to behold
I was told that the reason they changed was because the new trucks have bigger brakes and they didnt want people trying to install 15" wheels which would hit the brake calipers and because they went to the non-cone wheel nuts with the washers and didnt want people using wheels and nuts that didnt work together.
Old 07-15-2003, 08:41 PM
LxMan1's Avatar
Makes sense to me. Thanks guys.
Compact Spare Tire substitutions? yitzy Aerostar 11 05-18-2015 10:27 PM
Tire size help jhales91 1987 - 1996 F150 & Larger F-Series Trucks 2 10-02-2014 10:19 AM
Lug nut question? Natcox012 1987 - 1996 F150 & Larger F-Series Trucks 1 11-28-2013 10:04 PM
Anyone need a set of DRW rims? glennemay Massachusetts Chapter 2 03-31-2012 02:54 PM
85 F-250 rims on 70 F-250? Thomsen Brakes, Steering, Suspension, Tires, & Wheels 5 03-19-2004 06:29 PM
Tags
1993, 1997, 2001, 93, 98, bolt, expedition, f150, f250, fit, ford, lug, pattern, spacing, wheels
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
