1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Bed Removal
Old 09-03-2014, 11:12 PM
Cluney93's Avatar
Cluney93
Cluney93 is offline
Bed Removal
Hey guys looking for some advice. I have an 04 F250 that needs the bed removed. I've read a few stories of breaking parts just trying to loosen the bolts. Should I soak them in wd40 for a couple weeks or should I just grind them off and get new ones? Are new ones expensive to buy?
Old 09-04-2014, 05:47 AM
hodge5's Avatar
hodge5
hodge5 is offline
I would soak them first. Don't use WD-40- you need a penetrating oil like PB Blaster, Liquid Wrench, or the like. Soak them numerous times. When you put them back in, or for that matter new ones if you have to cut them off, make sure you coat the threads with antiseize compound.
Old 09-04-2014, 05:48 AM
ultrasks700's Avatar
ultrasks700
ultrasks700 is offline
I'm in the same battle as you right now. Go and soak as many as the bolts as you can from underneath with a QUALITY penetrant like PB blaster. Some are easier to get to than others. Then get as many T50 Torx bits as you can. And a good size breaker bar. I have yet to find any bits that wont break. Bought them at Napa and they are lifetime warrantied so i snap them and then bring em back and get new ones. Went to Sears and they gave me one they thought was stronger but nope snapped just like the rest. I have been able to get 6 of the 8 bolts loose but I think the last 2 are a lost cause. I plan on getting all new hardwear once i do decide to pull the bed.
Old 09-04-2014, 06:12 AM
redford's Avatar
redford
redford is online now
Received 1,549 Likes on 904 Posts
Don't even try to break them loose. Cut the heads off, then deal with what is left after the bed is removed. You'll only end up with a pile of broken Torks bits if you try to take the bolts out first..
Old 09-04-2014, 11:59 AM
Cluney93's Avatar
Cluney93
Cluney93 is offline
Alright thanks guys. Ill see how it goes lol
Old 09-04-2014, 07:16 PM
1977cutcher's Avatar
1977cutcher
1977cutcher is offline
Cut off the heads as stated above. I used a torch. Then cut the C clips with a grinder and start over with all new hardware. I got mine from the dealer however I think you can find it cheaper on line. FYI my new bed had the mounting holes in different locations however there where holes in the frame that mated up to the new bed. I just simply put the clips over the holes that I needed. This would be the perfect time to replace the fuel pump, rear shocks, ect.
diesel&coffee
07-22-2013 10:41 AM
1973Ford2004
13
07-12-2011 03:01 PM
thesaintnr1
06-20-2011 12:16 AM
SMS888
03-19-2006 06:36 PM
offroadguy
03-07-2003 10:21 PM
Quick Reply: Bed Removal
