Air Brake question - Ford Truck Enthusiasts Forums
Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
Air Brake question
Old 09-03-2014, 11:21 PM
DodgeAddict DodgeAddict is offline
DodgeAddict is starting off with a positive reputation.
Air Brake question
A while back I made a post about the air brakes on the company bucket truck & I tried the foot valve as another member mentioned but it has what seems to be a bypass of air in it also & the brakes won't maintain pressure after popping the park brake off or release the brakes
There are no leaks in the system
It's a F750 with a 8.2 GM Diesel
Old 09-04-2014, 12:38 AM
BruteFord BruteFord is offline
BruteFord has much to be proud ofBruteFord has much to be proud ofBruteFord has much to be proud ofBruteFord has much to be proud ofBruteFord has much to be proud ofBruteFord has much to be proud ofBruteFord has much to be proud ofBruteFord has much to be proud of
So you, put your foot on the brake, release the spring brakes and the service brakes don't hold?
Old 09-04-2014, 09:30 AM
I attempt to release the parking brakes & it immediately seems to bypass inside the foot valve & blows air out of the valve under the hood
Old 09-04-2014, 10:31 AM
David7.3's Avatar
David7.3 David7.3 is online now
Where is the beer?
David7.3 is a splendid one to beholdDavid7.3 is a splendid one to beholdDavid7.3 is a splendid one to beholdDavid7.3 is a splendid one to beholdDavid7.3 is a splendid one to beholdDavid7.3 is a splendid one to beholdDavid7.3 is a splendid one to behold
Does your air pressure build up as normal? Do you have the receiver drier on the truck? Are all the ports correctly attached, the threadle valve shouldn't leak any air, when you release the parking brake your charging the chambers, if you have a tear in one of those diaphrams it will force air back up to the foot valve and cause the air to come out of the open port, but the chambers have holes in them so you would hear the leak at the wheel. I would make sure the foot valve is in correctly, they are labeled and should come with spare plugs, to close off the none used ports.
Old 09-04-2014, 12:22 PM
I'll get my helper to try to release them & I'll listen for a leak It bulds pressure without any problems
Old 09-04-2014, 10:06 PM
dmanlyr dmanlyr is offline
dmanlyr has a great reputation on FTE.dmanlyr has a great reputation on FTE.dmanlyr has a great reputation on FTE.dmanlyr has a great reputation on FTE.dmanlyr has a great reputation on FTE.
Check your brake cans, I suspect one of them is bad. One of the signs of a blown diaphragm is a release of air at the foot treadle when applying the service brakes.
David
Old 09-05-2014, 02:25 PM
jpr38057 jpr38057 is offline
jpr38057 has a great reputation on FTE.jpr38057 has a great reputation on FTE.jpr38057 has a great reputation on FTE.jpr38057 has a great reputation on FTE.jpr38057 has a great reputation on FTE.jpr38057 has a great reputation on FTE.
Quote:
David
This ^^^^^
Old 09-07-2014, 07:29 AM
dragracer1956's Avatar
dragracer1956 dragracer1956 is offline
dragracer1956 is starting off with a positive reputation.
air brakes
Sounds like a bad brake can bleeding air back into the service/emer valve on the dash
Old 09-10-2014, 12:45 PM
How do I tell what type of brake chambers I have?
Thanks for all the replies & help!
Old 09-10-2014, 01:16 PM
tx2sturgis's Avatar
tx2sturgis tx2sturgis is offline
tx2sturgis has a very good reputation on FTE.tx2sturgis has a very good reputation on FTE.tx2sturgis has a very good reputation on FTE.
Quote:
Take pics and post them here.
Old 09-10-2014, 03:17 PM
DO NOT TAKE THE CHAMBER APART. The spring inside can kill you or take off fingers.
Air in brake lines HawkeyeF100 1973 - 1979 F-100 & Larger F-Series Trucks 10 07-07-2016 10:17 PM
Push Brake Pedal, hear AIR Pssssss z 97ford1 1997 - 2003 F150 2 11-28-2015 04:42 PM
would a bad vacuum booster cause weak brakes guitarplayer97 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 1 03-23-2015 10:59 PM
air over hydraulic brakes keeptruckin56 1973 - 1979 F-100 & Larger F-Series Trucks 7 03-15-2015 02:05 PM
ford 880 brake problem big ford rig Large Truck 7 03-14-2014 08:50 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
