Popping from carb after cam swap - Ford Truck Enthusiasts Forums
Old 09-03-2014, 11:19 PM
bluegoose95401 bluegoose95401 is offline
bluegoose95401 is starting off with a positive reputation.
So I put a new cam valve springs and double roller timing chain in my truck ( braket master II 544/544 lift 292/292 duration 108 lobe separation ) in my truck I can't get it to run well at all now it keeps poping out of the carb and shakes like it's missing any ideas timing is set to 10 btdc
Old 09-03-2014, 11:29 PM
wyckedcombo17's Avatar
wyckedcombo17 wyckedcombo17 is offline
wyckedcombo17 is gaining momentum as a positive member of FTE.
Either you flattened a lobe or you put the cam in incorrectly. Did you line up the timing marks when you swapped cams?
Old 09-03-2014, 11:35 PM
Quote:
Yes Iined up the marks and I had some one double check just to make sure
Old 09-03-2014, 11:36 PM
What's the likely hood of bent push rods. Is that more of a chance than wiping a brand new cam
Old 09-04-2014, 12:36 AM
OldMetal's Avatar
OldMetal OldMetal is offline
OldMetal is gaining momentum as a positive member of FTE.
First thing I would check is the wiring order, all it takes is to be one off
Old 09-04-2014, 12:43 AM
Firing order has been checked 4 times between 3 people there's a preaty bad exhaust leak I forgot to mention aswell all the vacume lines have been checked and vac plugs have been replaced as well as the carb base gasket
Old 09-04-2014, 01:03 AM
co425's Avatar
co425 co425 is offline
co425 is a name known to allco425 is a name known to allco425 is a name known to allco425 is a name known to allco425 is a name known to allco425 is a name known to all
Any chance you put the distributer back in 180* out???
Old 09-04-2014, 01:29 AM
tjnthesky tjnthesky is offline
tjnthesky is starting off with a positive reputation.
How is the compression?
Rule of thumb, check the compression. I did some work on an engine and had to go pick up a load about 45,ooo lbs. As I came to hills without a load it would start to miss. So I thought better see if a local shop could pin point my problem quickly. After spending 4 hrs shop time it got worse. Limped home and pulled the heads. Several mechanics said the guides were worn too far to use. Instead I grabbed some other heads I had knurled the guides a little and ground the valves. That was 10 years ago and still runs great. Just disturbing the valves a little could have burnt one or several. Also the valves may not be seating correctly. Easy enough to just check compression. My engine coughed through the intake just a little at first then continued to get worse. Thanks
Old 09-04-2014, 02:17 AM
Quote:
No that was also checked
Old 09-04-2014, 07:33 AM
somethingclever's Avatar
somethingclever somethingclever is offline
somethingclever has a great reputation on FTE.somethingclever has a great reputation on FTE.somethingclever has a great reputation on FTE.somethingclever has a great reputation on FTE.somethingclever has a great reputation on FTE.
pull a valve cover, rotate the engine so the cam is on it's base circle for each valve, and check to make sure all rockers are tight.
did you use zinc additive in the oil, and cam break-in paste supplied with your cam?
Did you test drive the vehicle and if so, how does it pull?
Old 09-04-2014, 12:16 PM
I used a hi zinc oil I did not use an additive I dint test drive it I can't even tap the peddle with out it popping
Old 09-04-2014, 01:55 PM
skidoodave's Avatar
skidoodave skidoodave is offline
skidoodave is gaining momentum as a positive member of FTE.skidoodave is gaining momentum as a positive member of FTE.
Pull the valve covers off and rotate the engine over and watch each valve to see if they are moving. I would measure the movement of each valve to see if they are all the same. If you find one that not opening as much as the others then you may have found your problem
What was your cam break in procedure? A 108 centreline is pretty tight for a truck motor unless it's for competition.
I would suspect you wiped a lobe or 2 off of the cam during break in. It happens a lot..
Old 09-04-2014, 02:02 PM
David7.3's Avatar
David7.3 David7.3 is offline
Where is the beer?
David7.3 is a splendid one to beholdDavid7.3 is a splendid one to beholdDavid7.3 is a splendid one to beholdDavid7.3 is a splendid one to beholdDavid7.3 is a splendid one to beholdDavid7.3 is a splendid one to beholdDavid7.3 is a splendid one to behold
Rocker arms too tight? keeping a intake valve open, 292 is a good bit of overlap. did you use new lifters? lots of things to double check, gotta pull the valve covers, do a compression test find out which one it is, or you can pull a plug wire off one at a time and see when the popping stops, that will be the one.
Old 09-04-2014, 02:40 PM
I will be pulling valve covers today to watch valve movement. Brake in was 20 mins at 2k just like the instructions said if the lobes got wiped what's the next step do I have to buy a new set or is that usually covered by warranty ?
Old 09-04-2014, 02:42 PM
Quote:
new lifters were used as for rockers being to tight it's a non adjustable valve train I dint switch to the adjustable
Big Orange got some new shoes! 1977 Highboy tlrtucker 1973 - 1979 F-100 & Larger F-Series Trucks 6 07-15-2016 04:32 PM
New 460 in 76f250 timing problems!! william16339 1973 - 1979 F-100 & Larger F-Series Trucks 2 06-27-2016 08:31 AM
No interior lights or turn signals after motor swap tlrtucker 1973 - 1979 F-100 & Larger F-Series Trucks 18 11-29-2015 04:24 PM
Cam with speed density brandon mauldin 1987 - 1996 F150 & Larger F-Series Trucks 2 08-18-2014 11:55 PM
New to the Ford seen..... depo20 New Member Introductions 1 09-08-2004 08:04 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
