Need help on x computer (pics of my new x) - Ford Truck Enthusiasts Forums
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
Old 09-03-2014, 07:10 PM
Nolo263 Nolo263 is offline
Nolo263 is starting off with a positive reputation.
I went outside to get the code off the computer so i can order a dp tuner. I used a borescope and got this off my computer.
It sais (Remanufactured) and the codes that i could read are (23cf-hc and Dpc-492)
I looked it up on the web and it sais its for a (2002 f250/350 automatic)????
Is this something that should not be on my x?? Is this a bad thing? Did i get the right code??
Thanks
Old 09-03-2014, 07:29 PM
aawlberninf350's Avatar
aawlberninf350 aawlberninf350 is offline
It's a Van Gogh
aawlberninf350 has much to be proud ofaawlberninf350 has much to be proud ofaawlberninf350 has much to be proud ofaawlberninf350 has much to be proud ofaawlberninf350 has much to be proud ofaawlberninf350 has much to be proud ofaawlberninf350 has much to be proud ofaawlberninf350 has much to be proud ofaawlberninf350 has much to be proud of
Almost, not quite. Should be 4 digits. Check out the pdf from DP Tuner attached below.
On edit; I checked a PCM list and the DPC-492 2C3F-HC comes back as QLJ2. Just like mine as it happens. If your X is 2002 it's all good. My CA truck and your X both have the GPCM.
Old 09-03-2014, 07:43 PM
Thats all it had on the gray conector.
Old 09-03-2014, 08:06 PM
By the way this is my new excursion . It has that i know of (Magnum force intake afe, 4" exhaust with muffler dumping after axle, tm torque master intercooler by tubonetics, ats billet trans with ats controller,) for some reason the turbo looks different than my old x can u all see something i did not list that jody needs to know for my tuner?
Old 09-03-2014, 08:13 PM
More
Old 09-03-2014, 08:23 PM
Also what lift do u guys think it has?? Trying to get ahold of the owner before me but hes hard to get ahold of. The slaesman that sold it to me did not know anything.
Old 09-03-2014, 08:27 PM
white Buffalo's Avatar
white Buffalo white Buffalo is offline
white Buffalo has much to be proud ofwhite Buffalo has much to be proud ofwhite Buffalo has much to be proud ofwhite Buffalo has much to be proud ofwhite Buffalo has much to be proud ofwhite Buffalo has much to be proud ofwhite Buffalo has much to be proud ofwhite Buffalo has much to be proud ofwhite Buffalo has much to be proud ofwhite Buffalo has much to be proud of
Looks very good! I can't see the turbo but I do see the regulated fuel return. It has an aftermarket intercooler, are you sure it has stock injectors? How about gauges?
Old 09-03-2014, 08:30 PM
Yeah its got gauges on the a pilar boost, egt and trans temp, it has so much crap on the inside its crazy.
How would i know if it has different injectors?
Old 09-03-2014, 08:31 PM
That could be a 300 series turbo, considering the angle of the air intake and filter. but it's hard to tell on my phone.
Old 09-03-2014, 08:32 PM
Quote:
How fast is it? Have u driven a stock 7.3L?
Old 09-03-2014, 08:33 PM
I looked up pics of 7.3 turbos and they said garret on the side this one does not say anything. It also looks kinda newish.
Its definately faster than my other ex was stock. It does not haul serious *** but it is not chipped the salesman gave me the chip but said that they changed the computer so im afraid to use it. I would rather get a new one.
Its also got a trans cooler with a fan on it and a filter under the x, it has some kind of air bags with leveling, and a bunch of other stuff.
Inside
Old 09-03-2014, 08:58 PM
Its not bad if my x has a truck pcm? And yes its a 2002.
Old 09-03-2014, 09:03 PM
No, not at all. Mine has struck PCM as well. When I get home I'll look at the engine pics closer on my laptop and get online.
Old 09-03-2014, 09:04 PM
But it sure looks nice!
Old 09-03-2014, 09:11 PM
Thanks i wish i knew excactly what it has in it. The previous owner was a texas supreme court judge so he is impossible to get ahold of. I also wish jody would get on here and look at all the posts and pics so i would not have to explain exerything again to him.
I also want to know what lift it has if anyone has an idea it has 34.6" nittos.
Default spring trivia MadWolf 1999 to 2016 Super Duty 2 03-16-2016 10:29 PM
The Rearend is singing in my truck. What can I do, what can I expect? greenstar 1999 - 2003 7.3L Power Stroke Diesel 33 10-20-2015 12:23 AM
Change oil soon..why? MadWolf 1999 to 2016 Super Duty 3 09-09-2015 01:28 PM
359 hd?? tink65 FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 6 03-19-2015 06:29 PM
Anyone know easiest way to do fogs with highbeams on a 2002 x? Nolo263 Excursion - King of SUVs 5 09-23-2014 11:45 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
