351 build underway - Ford Truck Enthusiasts Forums
351 build underway
Old 09-03-2014, 06:57 PM
Deadsquiggles's Avatar
Deadsquiggles Deadsquiggles is offline
Deadsquiggles is starting off with a positive reputation.
351 build underway
Operation GoFastBadAss is officially underway.
Finally found a 351 roller, cast number F4TE. The plan is to build it up and swap it into my Bronco.
I figure I'll start putting together a parts list. Please chime in if you see something wrong.
1994 Roller block, stock bottom end
GT40 heads
This intake: Intake Manifolds - Ford - 5.8L- Performer Series - Edelbrock, LLC.
New distributor (open to suggestions)
Gonna try and find some long tube headers (open to suggestions)
Not sure about a cam yet, trying to find something with good power off idle.
5.8l ECM
New Ypipe
CAI
Hope to get some pictures up and make some progress.
Old 09-03-2014, 09:09 PM
I was thinking this cam would be good.
http://www.lunatipower.com/Product.aspx?id=1654&gid=254
I can't really find much else with a desirable RPM range for a hydraulic roller cam.
Old 09-04-2014, 11:08 AM
Conanski's Avatar
Conanski Conanski is online now
Conanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud of
The cam you want is the Comp 35-512-8, notice it has 114 LSA.
There is no need for anything but a stock Ford distributor, there are no performance gains to be had with it.
Pacesetter makes some of the best fitting longtubes, avoid Flowtech and Hooker. There is also the OBX brand available on eBay that a friend of mine has installed on his Focus and F150 and he said the fit was excellent, these are stainless too so the price is also excellent. OBX Exhaust Header 87 96 Bronco F150 F250 5 8L V8 351 | eBay
Old 09-04-2014, 12:06 PM
I never even thought about 5.0HO cams.
What parts do I need to mate the new 351 to my E4OD since there's a 302 in there right now? And for engine control, all I need is a new ECM and then the 302 harness just plugs in or would I need the 351 harness?
Old 09-04-2014, 08:32 PM
Conanski's Avatar
Quote:
All windsor family engines use the same cams.
You need a 28oz E4OD flexplate, the 5.0 version is 50oz.
Harnesses are the same so get a 5.8/E4OD PCM and you should be good.
Old 09-04-2014, 09:53 PM
Quote:
Originally Posted by Conanski View Post
All windsor family engines use the same cams. You need a 28oz E4OD flexplate, the 5.0 version is 50oz. Harnesses are the same so get a 5.8/E4OD PCM and you should be good.
I thought there was a difference between the 5.0 cams and the 5.0HO/5.8 cams because of firing order. And there's no flywheel difference or is that a manual tranny only?
Old 09-04-2014, 10:00 PM
Conanski's Avatar
There are two different firing orders but both will work in any windsor family motor since the cam itself determines that. Otherwise all these cams are the same length with the same journal sizes and positions so the same cam will plug into a 289, 302, or 351.
Auto transmissions use a flexplate not a flywheel and there is a balance difference.
Old 09-04-2014, 11:13 PM
baddad457 baddad457 is offline
baddad457 has a very good reputation on FTE.baddad457 has a very good reputation on FTE.baddad457 has a very good reputation on FTE.
Well you CAN use the 5.0 flexplate, but you're not going to be happy with the "Whole Lotta Shakin Goin On" with it on a 351W
Old 09-06-2014, 02:10 PM
well the deal fell through. The day I went to pick the engine up, the guy decides to wait until I get there that he's gonna keep the engine to drop in a fox body. Thinking about sticking with 302 and building that just cause of availability. I think they can still make good power.
Performance intake manifolds? Hey351 1987 - 1996 F150 & Larger F-Series Trucks 10 02-21-2016 11:39 AM
1992 Ford F-250 manual build. Dan_Johnston Performance & General Engine Building 3 05-13-2015 05:13 PM
351w Intake manifolds Jon Seng Performance & General Engine Building 6 04-29-2015 09:10 PM
351w intake nightmare Fishbowlfire Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 14 12-03-2014 10:12 PM
400 / 6.6 - Which Intake will work with Factory AC? Augy88066 335 Series- 5.8/351M, 6.6/400, 351 Cleveland 4 09-05-2014 03:32 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
