new transmission acting funny??
Old 09-03-2014, 02:12 PM
trevorrules's Avatar
trevorrules
trevorrules is offline
my 95 powersroke 4x4 has a new tranny in it , the place I took it to to have it rebuilt is a very reputable place in Augusta,GA and its been acting really funny , iv taken it up there 3 times and they don't know what the problem is with it ..... can someone help with me I cant haul ANY loads because of this issue ??????
Old 09-03-2014, 02:21 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Mark Kovalsky is offline
Received 1,576 Likes on 1,054 Posts
That's a funny issue.
That's all the help I can give you since you haven't told us ANYTHING about what's wrong.
Old 09-03-2014, 02:25 PM
Skip1970's Avatar
Skip1970
Skip1970 is offline
a funny issue, oh them are the worst! hang in there maybe robin williams will come back from the dead and solve this important issue for you.
Old 09-03-2014, 02:33 PM
madpogue's Avatar
madpogue
madpogue is offline
Q: Why do clowns prefer clown cars with transmissions rebuilt by a particular reputable place in Augusta, GA?
A: They shift funny....
Old 09-03-2014, 02:37 PM
trevorrules
ok its gottin me more ***** than yall have seen but when I got it back the tranny shop it started to act like it didn't have any fluid in it , it would down shift into gears when I was driving, it stays in like 2nd gear then shifts really damn hard into 3rd gear, another is it would short shift into a really high gear when I would turn into a another road and bog down under 1000rpms and my foot was like half way on the accelerator, one week it acts fine the next week it does those symptoms , I hooked a scanner up to it and it flashed a speed sensor I replaced it and deleted it but that didn't help with anything ....
Old 09-03-2014, 02:43 PM
Skip1970's Avatar
Skip1970
Skip1970 is offline
check for proper ground
Old 09-03-2014, 02:51 PM
trevorrules
how do I check for the right one theres like 6 of them
Old 09-03-2014, 03:00 PM
madpogue's Avatar
madpogue
madpogue is offline
What scanner did you use, and what was the specific code? Have you scanned it since then?
Old 09-03-2014, 03:01 PM
Skip1970's Avatar
Skip1970
Skip1970 is offline
check all grounds.
Old 09-03-2014, 03:06 PM
trevorrules
okay doing that now, I wasn't paying attention what kind I was using I wasn't sure if that was right(being a speed sensor ) so I took it back to weeks transmissions they said it was(a speed sensor ) it didn't change any thing when I replaced it ... would yall think think that its a bad shift relay???
Old 09-03-2014, 04:20 PM
fordpride's Avatar
fordpride
fordpride is offline
Just cause the scanner said speed sensor doesn't mean it's the sensor. It could be the wiring have you/them checked the wiring ?
Old 09-03-2014, 05:44 PM
trevorrules
every thing checked out fine
Old 09-03-2014, 06:17 PM
madpogue's Avatar
madpogue
madpogue is offline
What device did you use?
Old 09-03-2014, 08:41 PM
BBslider001's Avatar
BBslider001
BBslider001 is offline
Huh? I am not even sure what this is talking about. Oh, the tranny shifting "funny". Mark can help you with that. Mark?
Old 09-03-2014, 09:58 PM
Mark Kovalsky
I don't know what a shift relay is. Maybe you mean shift solenoid? That is one guess. There are many other parts, too.
I think you need a scan tool that can look at live data to see what is happening.
Quick Reply: new transmission acting funny??
