2008 F350 breaking A/C hoses - Ford Truck Enthusiasts Forums
Old 09-03-2014, 11:43 AM
JCare JCare is offline
JCare is starting off with a positive reputation.
My F350, V10 has just broken the second discharge hose at the compressor within a two month time span. The break is at the aluminum block that goes into the compressor as it was described to me.
I obviously have something else going. The guys have looked to see if I have a broken engine mount and have side to side movement, but there wasn't any. They did notice the engine and transmission seemed to move forward a little when they would accelerate with the brake depressed, but other than that, are at a loss as to what could be causing this.
Both times this happened, I have been on the interstate for at least the past hour, pulling a 12', single axle enclosed trailer, with no more than 3000lbs max in the trailer.
Anyone have any ideas?
Old 09-05-2014, 12:44 AM
Torky2 Torky2 is offline
Torky2 has a very good reputation on FTE.Torky2 has a very good reputation on FTE.Torky2 has a very good reputation on FTE.
OK, no takers here so far on this one, so I'll spin something up...
I looked up your truck's compressor & discharge tube/hose assembly on rockauto.
It looks like the discharge tube assembly (motorcraft YF3568) when mounted on the compressor, goes radially outward from the compressor. The length of the tube end mounting to the compressor, with its muffler section, before it does a 90 degree turn forward and switches to hose, looks rather spindly. Long and narrow.
If the engine torqued CW/CCW on its mounts, the compressor-end of the hose would go up/down or left/right as mounted. Which means the hose would probably flex enough in those directions to avoid stressing the tube at its weakest point, which is where it goes into its mounting block.
However, if the engine is moving fore/aft, that movement would tend to try to compress/extend the hose in-line with the hose, not a direction that there is give in an A/C hose. That would be like having the hose disconnected and grabbing the 90 degree tubing turn with your hands, and working it forward/backward as mounted in the truck. That could fatigue the aluminum tube at the compressor block-joint.
A look at the failed tube may help verify this. If it broke at the front or the back (or both) the most where the tubing goes into the mounting block, that would show that it was forward/backward flexing of the tube that broke it.
If the engine is moving appreciably forward/backward, why?
As the rear axle goes up/down, or rear spring axle-wrap (axle housing rotating some on its axis, leaf spring ahead and behind the axle bend opposite ways), the driveline length changes. There is always a splined slip-joint to compensate for the changing length. If it is bound-up/very sticky, then the dynamic changing of effective driveline-length could push/pull the engine forward/backward via the transmission case.
Just blue-skying something here.
Old 09-05-2014, 11:21 AM
Thanks Torky. I am going to stop by and talk with them today a bit more. We have had a hot muggy week and they have been slammed. We discussed doing a little CSI investigation on the end that broke to see if we can tell how it broke, because he said that line has a loop so certain directional strains/stresses should be absorbed by it.
Whatever it is, has to be fairly consistent or occasionally violent, because I have probably driven the truck once a week, 10 miles or so each time since it happened in June.
Old 07-09-2016, 06:37 PM
Kevlar92174 Kevlar92174 is offline
Kevlar92174 is starting off with a positive reputation.
A/C hose fix
Having the same problem with my 2008 f.350 v-10.
Having a custom hose built by Amazon hose in Orlando
I have blown 3 motorcraft replacements and Ford has no answer why.
Old 07-09-2016, 06:38 PM
A/C hose fix
New design is on the left oem on the right
I'll let u know if it holds up better.
Broken exhaust manifold bolts bigblockford_390 6.4L Power Stroke Diesel 3 03-01-2016 10:37 AM
A/C Compressor Clutch Replacement V-10.Vegas 1999 to 2016 Super Duty 2 09-28-2015 08:05 PM
Breaking A/C Hoses JCare 1999 to 2016 Super Duty 24 07-17-2015 11:49 AM
Need help! 5.4 F250 ac line Ddsutton Modular V8 (4.6L, 5.4L) 0 06-29-2015 10:33 PM
04 Ranger air condtion hhorner Ranger & B-Series 3 12-03-2004 08:11 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
