is this a freeze plug?
Old 09-02-2014, 06:53 PM
cmb2481's Avatar
cmb2481
cmb2481 is offline
About a week ago, I started noticing antifreeze under my truck that wasn't there before. I was able to trace the leak to the passenger side of my oil pan and finally found this bad boy leaking. I believe this is a freeze plug, but I want to double check. Is this a relatively easy fix?
Thanks!
Old 09-02-2014, 06:58 PM
curtisbutlerjr's Avatar
curtisbutlerjr
curtisbutlerjr is offline
freeze plug
yes it is. That dose not look that bad to get at ,but internal condition of cooling system may need attention and more freeze plugs may be on the way, I hope not the ones in the back of the block are to much work.
Old 09-02-2014, 07:04 PM
dixie460's Avatar
dixie460
dixie460 is offline
Yep, that's a freeze plug. Also known as a frost plug or core plug if the computer operator... oops I mean parts guy/gal can't find it in the system at the parts store. Get BRASS ones if they're available, not steel.
I'm guessing you'll want to know how to replace it too!
Smash a hole in the center of it with a chisel, pry it out sideways, clean up the bore, and use a seal driver (or a socket) that just fits the inside diameter of the new plug to drive it in square.
Old 09-02-2014, 07:05 PM
cmb2481's Avatar
cmb2481
cmb2481 is offline
so just hammer the sucker in there is what you're saying. sounds easy enough lol
Old 09-02-2014, 07:06 PM
cmb2481's Avatar
cmb2481
cmb2481 is offline
im assuming antifreeze is going to go everywhere when I take the old one off?
Old 09-02-2014, 07:10 PM
dixie460's Avatar
dixie460
dixie460 is offline
Yeah you just drive it in there, straight in, with a socket or seal driver that just fits inside of the plug. If you let it get off center then it'll get all messed up and you'll probably bend the plug trying to pry it back out for another try.
I also edited my post to tell you to get brass ones instead of steel!
Old 09-02-2014, 07:12 PM
cmb2481's Avatar
cmb2481
cmb2481 is offline
Ok I will do that. Am I gonna lose all my coolant taking the old ones off?
dixie460's Avatar
dixie460
dixie460 is offline
And yes antifreeze will go everywhere, watch your dogs or other animals.
If you're feeling REALLY brave and don't want a big mess you can remove the drain plugs from the block, but with the shape that freeze plug is in I wouldn't mess with the drains (one on each side near the motor mounts I believe).
bashby's Avatar
bashby
bashby is offline
Yes all the coolant will come out. Even if you drain the system its gonna make a mess.
Old 09-02-2014, 07:14 PM
cmb2481's Avatar
cmb2481
cmb2481 is offline
and i just put brand new coolant in it too. dang original parts lol how many freeze plugs total are there? It's a 1994 F150 inline 6 automatic if that makes any difference
dixie460's Avatar
dixie460
dixie460 is offline
Oh damn I lied. I was thinking of a Windsor engine, but it looks like you have the 300. Not sure where the drain is on those blocks. Gotta be near the bottom somewhere. Catch can should contain the mess if you do remove the plug.
Old 09-02-2014, 07:17 PM
dixie460's Avatar
dixie460
dixie460 is offline
Not sure how many freeze plugs on a 300. Count on at least one in the back though. You'll have to remove the transmission if that's the case. Not a hard job, just time consuming since you have to disconnect driveshafts, trans cooler lines, stuff like that. Couple hours maybe to do the ones in the back.
Old 09-02-2014, 07:22 PM
cmb2481's Avatar
cmb2481
cmb2481 is offline
Well, they've waited 20 years lol so I'm not in any hurry. just out of curiosity, is the 300 inline 6 really as great as engine as I've heard?
Old 09-02-2014, 07:27 PM
dixie460's Avatar
dixie460
dixie460 is offline
I honestly can't tell you since all my Fords except 2 have been V8's. The 2 exceptions were a 4.0 V6 Ranger and a 2.9 V6 Bronco II, so I can't give you an honest answer. They SEEM to be reliable engines, as long as you take care of them (as is the case with anything mechanical) and don't expect too much in the way of power.
Old 09-02-2014, 07:42 PM
curtisbutlerjr
there are two in the rear of the motor
Quick Reply: is this a freeze plug?
