LED Side Marker Lights
I saw this idea in another thread, but haven't been able to find it, so I thought I'd make my own.
I started with the side markers from a parts truck I had. I picked up the led strips on ebay. The strips are the perfect size for the groove in side the housing. There is a thin divider between where the 194 bulb normally sits and the groove. I removed it with a file, as to avoid splintering the aging plastic. Then I filled the bulb cavity with a metal putty up to the level of the groove. I used some tape on the backside to keep it from oozing out. I trimmed the led strip to nine lights, which makes it a perfect fit with the ends bent up a little. I tested the strip prior to putting it in, to make sure I could power it from the middle of the strip. For the connections, I drilled small holes through the copper contacts, all the way through the housing. I enlarged the holes on the backside to allow the wire insulation to fit. Then it's just a simple solder job.
Man are these suckers bright! This is actually part of a full led conversion, coupled with relocating my battery and hiding all under-hood wiring. I plan on posting a thread on this process in the near future also.
I finally got around to installing my side markers today.
My truck's wiring is really unmolested, so I didn't want to use wire taps or cut the original sockets off. My solution was to replicate the base of the 194 bulb. I used a piece of plastic the right thickness, trimmed to the same width as a 194. Then I stripped enough insulation from the wires to wrap around the plastic piece, just like the wires do on the 194. I tinned the bare wires before feeding them through holes drilled in the plastic pieces, and wrapped one from the front, the other from the back. Then it just slips into the socket exactly like the 194 bulb does. I probably should go back and take a pic for clarity on these, but anyway, here's the finished product...
Those turned out great. I got some strip lights too but been having a heck of a time making a good connection to the strip. I got some of those clamp on pigtails but they don't fit worth a flip. I'll be looking forward to some detail pictures if you decide to pull one out for a photo shoot.
Nice modification.
I removed the single filament socket from the cargo light on my '69 F100, replaced it with an 1157 socket and installed a white/red switch back LED.
The cargo light still functions as a cargo light when the **** on the dash is pulled out but, when I step on the brake pedal the cargo light doubles a high mount 3rd brake light.
I also have LEDs in the tail lights.
I have these,
Work well in my Trailblazer lift gate and wife's lamps lol
Amazon.com: XKTTSUEERCRR Waterproof Blue LED 3528 SMD 300LED 5M 16.4Feet Flexible Light Strip 12V 2A 24W 60LED/M: Musical Instruments
