Sudden power loss (but still running). Thoughts?
Hi all,
I was driving around doing some errands today, and kept noticing that my engine just felt weak. It also was harder to start than normal (like the battery wasn't fully charged).
However, the more I drove it, the worse it got. I had to floor it to get up to speed, and when I was pulling out onto the interstate, I noticed that once I got over 2500-ish, RPMs, I had FULL power loss. O2 peaked lean, and it felt like the engine was just spinning without doing anything.
Shifting the RPMs back down and cruised the rest of the way home.
Things I noticed. My AFR seemed normal. Was still 15.0 or so at cruise, 12.5 on accel. 11 on full accel.
Also, my cruising vacuum was the same as normal. Around 13 or so.
Any thoughts? I haven't had a chance to look into it more, but when I popped the hood, everything looked completely normal.
I'll let you know if I find anything, but was curious on your guys' thoughts.
I'm curious how that happened since the hold down nut was tight and I couldn't make the distributor turn without loosening it (that and I'm pretty sure I didn't set it to that).
Either way, easy enough fix!
As for the lean spike, my guess is that was from a change of vacuum in the engine or something. Maybe it stopped pulling fuel for a sec. Dunno.
CTDpower
1997-2006 Expedition & Navigator
12-16-2016 02:28 AM
Jon351m
01-26-2015 01:50 PM
