Upfitter Wiring Question
To install the Upfitter switches you will need the switch panel and the harness/relay pack.
Switches: AL3Z-13D730-AA
Wire Harness/Relays: BC3Z-14A303-B
Here are the installation instructions from the Ford Body Builders Guide:
https://www.fleet.ford.com/truckbbas...tml/Q157R2.pdf
Ryan is correct, you need those two parts to install your up fitters. You can buy them from Ford or buy them on eBay from a seller such as Tasca Parts or Fairway Ford (as I did). However in answer to part of your original question, the harness plugs to supply the relay pack and subsequently the switches are already located behind your dash. Pull out your dash panel, mount your relay pack and switches, and plug them in. That's it.
Necronommicon
Electrical Systems/Wiring
03-12-2016 06:52 AM
yellowpony281
6.7L Power Stroke Diesel
02-16-2013 04:58 PM
