EGR Delete VS EGR Cooler
Old 09-02-2014, 04:27 PM
ves83's Avatar
ves83
ves83 is offline
I'm trying to decide which one to go with. Does the EGR Cooler take care of the common problems cause by the Egr of course I know if it fails it won't help. I just read different posts saying the delete might flash check engine lights and codes. Can I gets some personal experiences and techs to wage in on this one please?
Old 09-02-2014, 04:49 PM
schwank's Avatar
schwank
schwank is offline
Just picked mine up from getting a Bulletproof EGR cooler installed. For me, I would rather not do a block off that requires a dedicated software flash to turn off the CEL. On top of that, should my state decide to add emissions testing requirements for my truck, I have all such equipment in place.
Here is one brief article discussing some pros and cons... just happens to be from the shop that did mine.
6.0L Powerstroke EGR Delete
Old 09-02-2014, 05:15 PM
MisterCMK's Avatar
MisterCMK
MisterCMK is offline
It can never leak if it isn't there.
Old 09-02-2014, 05:28 PM
Erock2006's Avatar
Erock2006
Erock2006 is offline
When I got my truck a couple months ago, the previous owner had put in a BulletProof EGR cooler. Here is a link from their website which is also educational. What they say make sense to me. As always with a vendor, keep in mind that they are selling something.
http://www.bulletproofdiesel.com/Articles.asp?ID=304
That said, there seems to be consensus here that something should probably be done, at the very least you do your coolant flushes etc. Read the 6.0L tech forum intro 'buying a used 6.0L' by Bismic.
Old 09-02-2014, 05:37 PM
69cj's Avatar
69cj
69cj is offline
A plugged oil cooler is the root cause of egr cooler failures. Proper coolant maint. is the cure.
Old 09-02-2014, 05:38 PM
Rusty Axlerod's Avatar
Rusty Axlerod
Rusty Axlerod is offline
^^---I found this to be an informative, complete and unbiased article. Bullet Proof Diesel sells a well made part with a lifetime warranty. I would also add there are other suppliers on the net who are less expensive but I haven't seen one back up there work like that.
BFlemsr
11-16-2012 06:38 PM
mmenzies
05-14-2011 02:02 PM
caere
1999 to 2016 Super Duty
07-05-2010 01:11 PM
Headviking
06-06-2009 09:38 PM
joe blow
04-15-2009 05:39 PM
Quick Reply: EGR Delete VS EGR Cooler
