zf6 fluid - Ford Truck Enthusiasts Forums
zf6 fluid
Old 09-02-2014, 03:32 PM
renoduckman renoduckman is offline
renoduckman is starting off with a positive reputation.
zf6 fluid
What is a good fluid to run in the ZF6 speed. I have used the regular mercon and have some hard shifting issues once in awhile.
Old 09-03-2014, 07:52 AM
pawpaw pawpaw is online now
pawpaw is a splendid one to beholdpawpaw is a splendid one to beholdpawpaw is a splendid one to beholdpawpaw is a splendid one to beholdpawpaw is a splendid one to beholdpawpaw is a splendid one to beholdpawpaw is a splendid one to behold
If your asking about your 2002 F-250 tranny & it calls out auto-tranny fluid, you should be using Mercon-V as this TSB indicates. Fulltext TSBs | Ford Trucks
Mercon-V is a semi-synthetic friction modified fluid that's back specified to replace Mercon. It has a better quality base oil & additive package than the old Mercon recipe, so you might find you'll get better shift quality using it. Let us know how it goes.
Old 09-03-2014, 12:57 PM
6 speed
Will do. I apprecaite the input.
zf5 swap to zf6 questions '97f350supercab 1987 - 1996 F150 & Larger F-Series Trucks 4 12-04-2016 08:06 AM
ZF manual trans 6 speed fluid, what are you using? cavitation 1999 to 2016 Super Duty 27 05-21-2015 06:52 PM
ZF5-47 interchange with ZF5-42? f300i6 1987 - 1996 F150 & Larger F-Series Trucks 2 08-07-2014 04:25 AM
ZF6 and speedo Diesel_Brad 1973 - 1979 F-100 & Larger F-Series Trucks 0 11-01-2013 04:46 AM
WHAT YEAR IS THIS ZF TRANSMISSION klassik1 1987 - 1996 F150 & Larger F-Series Trucks 2 05-15-2013 04:36 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
