Oil Change Interval
08-30-2019, 07:36 AM
I always check that the IOLM has been reset, which is generally the case. I'm very particular about my vehicles so I do check my oil almost every time I fill up. If it were ever to be low, smell funny or look bad I would get my oil changed early. Lucky for me it's always been good. We live in a world of data, statistics & algorithms. The people who work on the data & algos are very good at determining what variables predict the desired outcome within a given range. I'm very confident the OLM is accurate so no need for me to worry.
08-30-2019, 01:03 PM
------ I'm very particular about my vehicles so I do check my oil almost every time I fill up. If it were ever to be low, smell funny or look bad I would get my oil changed early----------
Exactly....... and YOU know if the oil was synthetic or dyno which will change the "interval". ....
08-30-2019, 01:34 PM
I use Synthetic Blend, as recommend in my owners manual, which means my IOLM will be accurate.
12-19-2019, 12:39 PM
on
Change the oil when it's dirty ~ if engine oil looks like dark honey and is free from particulate matter ~ why change it ```
12-19-2019, 03:56 PM
Much of the Particulate Matter is too small for you to see suspended in the oil...... If they were only worried about the BIG CHUNKS, the filter would be made of window screen.
12-19-2019, 04:08 PM
on
Hi Steve ~ I have a filter on this truck that filters down to 1 micron ~ cleaner of than off the shelf ```
12-19-2019, 04:13 PM
that's my point... you can not see 1 micron... and it is taking CRUD out that you cant see....... so don't wait until you can see "particulate matter".
12-19-2019, 04:16 PM
on
Will never see particulate ~ it filters that fine ~ the oil is cleaner then when it is sold ~ the filter is changed every 3 to 5 thousand miles and a quart of fresh oil is added ```
Over
12-19-2019, 07:32 PM
your changing your story... You said run the oil as long as you SEE NOTHING...
That's not right. How do you know it is free of matter by LOOKING.. You can have particulate matter in the oil and you CANT see it... If you had said "change every 5000 miles", then I would agree.
12-19-2019, 07:34 PM
on
I said: " Change oil when it's dirty "
12-19-2019, 07:37 PM
on
Steve it's been good talking to you ~ didn't mean to contradict anything you'v said ~ what you said makes sense ~ What we've both said is true ```
jschira
Oil & Lubrication
26
08-24-2019 08:07 AM
mc1502
2009 - 2014 F150
37
04-15-2015 10:43 AM
wolf189
2004 - 2008 F150
01-30-2011 06:54 PM
CptSD
07-07-2007 02:00 PM
eco
Oil & Lubrication
12-25-2006 04:29 PM
