Coolant leaking from crack in head?
Are you sure its not coming from the tube just above that point, the tubes the red arrows point to rust through, you might be seeing the result of a pin hole shooting straight down. The bottom of the tubes rust through before any other point.
Small tube can and will too and doesn't look good in your picture, but the larger tube tends to rust through first.
If not how about reposting your picture with an arrow pointing to where you believe it leaks, same way I did it. If you're not sure how to do so, right click on the picture and click "copy" open then paste image into "paint". Use pencil or brush in paint and a contrasting color of your choice to draw an arrow. Save the picture to known location in your computer, then upload same as you did the first time. Once uploaded you can delete the file, desktop for example is a handy location.
Looks like it's leaking pretty good, probably won't need a pressure tester. Warm it up, hose off the coolant with water, blow it down with air, and watch for the leak. I say warm it up because if your radiator cap is working right then it'll let the system pressurize on it's own.
I agree with the above posters... that tube likes to spring a leak so it's worth another look.
If it's leaking there, then it's the intake gasket that had failed. Next step would be to buy new bolts since that one where the arrow points is gonna be corroded.
Its not a hard job to tackle, but it's gotta be fixed. Let us know what you plan? If you do it yourself, we can help you out.
Sure. You might want to find an EGR tube before you take the manifold off, since they are thin and like to break. Unless you don't have smog checks in your state and don't care about EGR.
Don't cheap out on the gaskets either. Get GOOD ones from a respectable brand. Now me personally, I'd probably put a LIGHT coat of Permatex #2 non-hardening sealer on each side of the gaskets, but that's my preference and I'm sure if you took a poll you'd get answers all over the place.
