Project Toy Hauler
#46
#48
Gauge readings
Can anybody help me out with the normal readings on the various gauges. I've got the torque Pro app on my cell phone and I've managed to get some of the gauges working.
The tach reads about 2200 rpm at 65 mph with 4.10 gearing. The hpop shows about 1200 at this speed. The Map shows 2/3 lbs at about 60 with very little load. it shows about 6/7 lbs at 65 going up a slight incline and goes up to 10/12 if you accelerate briskly.
The ebp gauge holds pretty steady at around 20 psi going down the road and about 15 at idle. The ipr gauge ranged from 20 to 30 percent depending on load/speed. Engine oil temp ranged from 195 at 60 mph to 214 at 75 mph. The trans temp ranged from 185 at 60 mph to 200 at 75 mph.
This was on a five hour run each way carrying maybe 1500 lbs of cargo.
Thanks
Chris is the son of a friend and fellow Patriot Guard Rider. There is a drive on to name the new I-10 bridge in Mobile after him. He was a hell of a good young man.
Thanks
carrfamilynj
24
01-10-2014 03:17 PM
