Leveling Springs Didn't Quite Level It: Spring Isolator Dimensions or Height Fixes for 1990 F150 - Ford Truck Enthusiasts Forums
Old 09-02-2014, 11:17 AM
SkiBikeClimb SkiBikeClimb is offline
SkiBikeClimb is starting off with a positive reputation.
1990 Ford F150 Custom, 2wd, 4.9 L6, no suspension modifications up until this project.
Replaced the shocks with the appropriate Rancho 5000's all the way around and decided to add new Skyjacker leveling coil springs up front. Everything went on great and rides fine, but upon measuring the wheel-well height I am still sitting just shy of 1" lower in the front. I did not replace the spring isolators that sit between the coil springs and the spring seats, but I can't imagine new ones add much height. I would like to get it leveled out prior to shelling out for new tires and an alignment.
Anyone know of spring spacers that will bump the height up about 1"?
Better yet, anyone know the dimensions of the spring isolator pads? It looks like there are some out there offered by Energy Suspension and others that have various heights and could raise the height just a touch, but without tearing apart the front end again I don't know the dimensions. Figured this approach would kill two birds with one stone, new pads and some added lift.
Unrelated note, is it possible to fix the camber issue that the leveling springs caused? |\------/|
Leaf spring rear shackles and bushings Buck268 2009 - 2014 F150 5 08-25-2016 10:38 PM
leveling kit, new coils, or air spring? DieselMechanic87 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 6 09-14-2015 12:25 AM
Add a leveling kit to my 6in lift? fishbones182 2009 - 2014 F150 0 02-01-2015 08:36 PM
Leveling Springs Didn't Quite Level It: Spring Isolator Dimensions or Height Fixes for 1990 F150 SkiBikeClimb 1987 - 1996 F150 & Larger F-Series Trucks 0 09-03-2014 12:49 AM
48 f1 front fender height train2 1948 - 1956 F1, F100 & Larger F-Series Trucks 13 05-11-2012 01:48 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
