Front end noise while turning
If you can replicate the problem on demand, watch the dash when you do it to see if the traction control icon flashes. I had this happen routinely on a 2010 F-150 and for a while, I swore it was a tire rubbing. As it turned out, the truck thought I was in a roll and was applying the brakes to one front wheel to try to stop the roll. For me, it was usually when turning sharp into my parking lot at work.
A test drive might be a good next step, JPMF250. Also, I'd like to escalate this to your regional customer service manager so they can help. To make that happen, send me a PM with your full name, best daytime phone number, VIN, current mileage, and servicing dealership. I'll do the rest.
Crystal
Crystal
Hi JPMF250,
All you have to do is click on the "FordService" at the top left of this post and select the option to send a private message from the drop-down menu. If you'd prefer, you can contact our Customer Relationship Center at 1-800-392-3673; they can offer the same assistance that I can.
Crystal
Crystal
I offered a suggestion a few posts up. My bet is still the traction control kicking in due to a yaw sensor that is too sensitive. By looking to see if the traction control icon is flashing on the dash when the rubbing is happening, you could say for sure one way or the other that it is or is not traction control (roll stability - more specifically).
I'll be happy to arrange for a follow-up call from your CSM. I checked out your case notes and see that he had a hard time getting in touch with you; send me a PM with a verification of your best daytime phone number and your current mileage. I'll get this into his hands.
Crystal
That's all I have. I feel your pain as it drove me nuts looking around on my truck trying to find it. I looked everywhere under the front end looking for rub marks on the tires, wheel well liners, control arms, etc and never found anything. I just finally lucked out and saw the traction control icon flashing early one morning in the parking lot and figured it out. From then on, I just disabled traction control and never had an issue after that. Good luck!
#28
I've had the same noise for 3 years. My traction control light did not come on either, but, after reading this thread I decided to turn off the traction control by holding the button for 10 seconds. I drove through the dip into my neighborhood that makes the most noise and NO MORE NOISE!!! If I were you I would give it a try before taking it to the dealer. Good luck.
#30
lloydmiiller
08-27-2009 10:09 PM
