"missing" poor milage etc...
I have been having an issue for some time. Here are some of the symptoms.
I thought it may be a stiction issue, used oil additive for the hell of it, seemed to help MPG etc for a short time. I know of several things that may be the cause. Will probably take to the dealership. I hate to do it but don't have the back or time to do the work myself. Any ideas would be appreciated.
Thanks!
Steve
- Seems to be a slight stutter like a miss in a gasser, mostly feel at cruising speed. It's very subtle.
- Bad fuel milage, probably getting 11-12 mixed driving on summer blend
- If I start and put in gear right away, sometimes it will lope really bad like it's might stall. Put in park and try again and usually fine. Seems to do it more in reverse but that's how I generally start off.
- Some long cranking starts, mostly cold but sometimes hot. Will also fire right off.
- On occasion, it will run terribly until warm. Let it set for about a week when I was out of town, started but got on the road and barely ran. happened a couple of times, if I recall temps cooler when it happened.
- One more thing, oil and coolant temps running over 200 in normal driving, but it's been hot. I can't recall what's normal. I have the BPD remote oil cooler etc, see sig.
Thanks!
Steve
Thanks!
Steve
Thanks!
Steve
No codes thrown that I've found. I have a pretty new 6 phase BPD FICM, The FMV is 48.0 KOEO, cranking and idle. Need to check WOT. No way to monitor fuel pressure. The ICV is .22 KOEO and 1.10 at idle.
I don't trust dealer service centers. I've never had a good experience, NEVER! I have no real choice at this time. I do want to go in armed with as much info as possible. Doesn't really matter though. I had an issue with my 7.3, I told them that I thought a particular sensor was bad after I had already replaced the CPS a few times. They dismissed me and diagnosed as bad injector o-rings. $1000 later, I stalled again on the way home! I was pissed. The o-ring may have been leaking some but was not the problem. Guess what, it was the sensor I told them about!
I can't find any good diesel shops around my area. If anyone know of a good shop in the Illinois/iowa Quad Cities area, please let me know.
Thanks!
Steve
Thanks!
Steve
RedDevil460
08-12-2016 06:07 AM
DickNitro
12-26-2015 08:18 AM
blowin_smoke_1977
03-19-2013 06:21 AM
eyyu
68
12-22-2011 01:59 AM
