Help! - Ford Truck Enthusiasts Forums
Help!
Old 09-01-2014, 06:08 PM
dgford99 dgford99 is offline
dgford99 is starting off with a positive reputation.
Help!
question to anyone with experience with 99's V6 4.2. just had intake gaskets replaced, still not running right. Tends to buck a bit when I go to accelerate from a stop. Replaced VMV, still not the problem, thinking it may be the charcoal canister. any other suggestions ?
Old 09-03-2014, 09:19 PM
Dr. Dirt's Avatar
Dr. Dirt Dr. Dirt is offline
Dr. Dirt is gaining momentum as a positive member of FTE.
is there a CEL on or anything?
Old 09-04-2014, 04:56 AM
To Dr.Dirt
Quote:
not at the time, but it recently did come on. Lean codes p171&174, banks one&two, have had all obvious vacuum lines done, Mass air flow sensor has been replaced, I think now it's both air and fuel. Your thoughts on it. Thank you
Old 09-04-2014, 08:09 PM
Dr. Dirt's Avatar
no broken vacuum or PCV hoses? intake manifold torqued down correctly? intake tube loose on throttle body?
Old 09-05-2014, 04:16 AM
Dr.Dirt
Quote:
Intake gasket was done by Ford, have checked those, did not think it was these. All other vac lines have been replaced. Rubber ones that is. Have one plastic one running from VMV, and one from EGR. Will check those you suggested and will get back to you. Thank you
Old 09-05-2014, 03:42 PM
Bluegrass 7 Bluegrass 7 is offline
Bluegrass 7 has a good reputation on FTE.Bluegrass 7 has a good reputation on FTE.Bluegrass 7 has a good reputation on FTE.
The codes 171/174 tells you about all you need to know.
The Air Fuel relationship is upset. This causes drivability issues because it's not a normal condition.
There is still an air leak as detected by the OX sensors for both banks as excess air in the exhaust.
A verify of the fuel tables will show this.
It would be nice if mechanics would use there test equipment to look at these things instead of guessing both before and after the work is done.
Good luck..
Old 09-06-2014, 07:24 AM
To bluegrass 7
Good luck..
Been replacing vacuum hoses the last couple of yrs because of lean codes. Something caused the intake gasket to go other than age of vehicle. Did find out that this V6 4.2 is notorious for the gasket to be replaced. Your right that these mechanics need to use these tools to get to the root of the problem, unless it was meant to keep bringing me back so they can have access to my bank account, LOL.
Old 09-06-2014, 07:31 AM
Dr.Dirt
Was able to check PCV, there is vacuum there, haven't checked torque on intake, intake tube is tight, unless its worn, tube going from VMV to intake seems like its collapsing a bit. I don't think it's supposed to b doing that. Acts like there is blockage coming from the rear fuel system. Thank you
Self problems '99F250 1999 to 2016 Super Duty 3 11-04-2016 04:32 PM
99 explorer 4x4 will not engage inabind15 Explorer, Sport Trac, Mountaineer & Aviator 0 01-08-2016 10:34 AM
99 v10 bad fuel pressure demoman01 Modular V10 (6.8l) 23 09-30-2013 12:25 PM
99 expedition door locks "weak" speed Expedition & Navigator 1 08-25-2013 03:02 AM
What's your MFG. date? BIGBEAR6 1999 to 2016 Super Duty 26 08-12-2009 07:39 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
