starting problems - Ford Truck Enthusiasts Forums
starting problems
Old 09-01-2014, 04:35 PM
sparticus220 sparticus220 is offline
sparticus220 is starting off with a positive reputation.
starting problems
Hello, ive been using this forum for a long time now and it has helped me keep my truck running for 5years now. This is my first post so please forgive me if i post in the wrong place. Anyway, the last couple days my truck( 1997 f150 4.6l) has been having startinv issues. At first it would just turn over and not start then the battery would die. So i bought a new battery and yesterday now its starts sometimes but when trying to start it while its ttuning over it stops then starts turning and starts up. Then i drive whereveri am going when i get back in to start theres nothing.its not turning over at all but when i turn the key there is a loud single knocking noise coming from behind the dash near the passenger floor vent. Actually there ate two noise from the same area, one when i initially trun the key and another when i release the key. But after just sitting there doing this it will finally turn over and start. Can anyone please help me with what this is, there are no codes being thrown besides my dreaded P0401 which i cant seem to get rid of either. Ive changed every part that has to do with the egr system and cleaned the throttle body replaced vacuum lines and still the code. But anyway any help i would be greatly appreciated. Sorry for the long winded writing.
Old 09-02-2014, 06:51 PM
carguy94 carguy94 is offline
carguy94 is starting off with a positive reputation.
next time the truck does not start check for power at the starter when your turn the key to crank. how your gas mileage lately no froze bound engine accessories. check system voltage also.
Old 09-02-2014, 07:04 PM
My gas mileage has dropped alot but i assuming it was the p0401 i have a bad sputter or surge because of it. I have had that code and chasing it for almost a year now
Old 09-02-2014, 07:27 PM
Bluegrass 7 Bluegrass 7 is offline
Bluegrass 7 has a very good reputation on FTE.Bluegrass 7 has a very good reputation on FTE.Bluegrass 7 has a very good reputation on FTE.
You have a cable from battery to start relay.
A cable from start relay to starter.
You have a ground cable from the battery to the starter area.
You have a starter. The starter could have worn brushes.
The issue could be any of these items on a truck of this age.
You have to inspect all of them for an issue and tightness and make some tests.
Good luck.
Old 09-02-2014, 07:29 PM
which issue would you like help with. if the no crank no start issue check power and ground at the starter when you try to turn the engine. just because you have a code present does not mean it has anything to do with the problem. is your truck a automatic or standard
Old 09-03-2014, 06:42 AM
Ty for your reply. I will check thise things today it was pouring here yesterday. So what is that clunking noise coming from the bottom of the dash when i turn the key. Its not a continuous clicking its just one clunk.
Old 09-03-2014, 06:47 AM
Sorry carguy i did not see your post. I would like help with the both but can we start with the starting issue. It did it again this morning..starts up fine drove into work stopped to get coffee then nothing just a clunking sound from bottom of dashboard. Got to work checked all connections and seem to be tight and corrosion free. I have power to starter. With just me its hard to pinpoint it seeing how you have to be turning the key for it to happen.
Old 09-03-2014, 08:03 AM
ok I see what you mean its pretty hard to do the power check while cranking the engine. these older ford starter used to have issues with internal grounding of the starter. the clunk you here is probably the starter solenoid on the starter if its engaging then the contacts in your solenoid could be poor and its getting power but not the starter. as suggested you could have a lot of internal starter issues but usually you just replace it. make sure the engine turns freely when it will not start by hand. but the power measurement at the starter during cranking are very important along with your starter ground but it sounds ok have you tried lightly tapping the starter with the wood of a hammer. also when you check for power make sure it when it will not start.
Old 09-03-2014, 08:12 AM
Hmmm, i really dont know how to explain it. You know the noise you get from your ac unit when the blend door changes positions. Thats the type of noise i hear but obviously the blend door doesnt have anything to do with starting. It is definitly.not coming from outside the truck. It is coming from inside behind the dash board around the glove box area. Am i just hearing a resinent sound? The other day it took atleast 50 turns of the key before it just started like nothing was wrong. So i was able to really hear where the noise was coming from. I do have a some mechanical knowledge but i have never heard this sound before.
Old 09-03-2014, 08:33 AM
do your dash lights or head light dim down when you try to crank the engine and it will not crank. usually most all power is drawn to the starter so if you tried to switch hvac controls on or off roll a window down it would not do it until the starter disengaged. I had the exact same truck as you and it would make a clicking noise from the dash and when the blend door broke it made a thud sound from behind the dash. do you notice it when the truck cranks. have you jumped the solenoid to see if it will start
Old 09-03-2014, 08:34 AM
Now im second guessing myself, lol its so hard because i just went out and tried to get it to do it and the truck started every dag on time i tried maybe 30 times and couldnt get it to do it. I dont get it..im so confused
Old 09-03-2014, 08:36 AM
No it only makes the noise when it wont start.
Old 09-03-2014, 08:37 AM
I do hear a click but its the relay in the fuse box not the clunk i hear from the dash cupholder area.
is it heat related try a hot test drive and shut it off see if it will not start these issues really get you thinking and annoyed. is your hvac turned off
Old 09-03-2014, 08:38 AM
No nothing dims, still have all lights dings everything works
Can't get engine to start with key, please help ryan73ford 1973 - 1979 F-100 & Larger F-Series Trucks 14 02-09-2017 04:59 PM
2003 F350 6.0L No Crank Nate Wengerd 6.0L Power Stroke Diesel 7 08-03-2016 11:07 AM
Need starter help!! crrnchris 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 12 05-11-2016 06:12 PM
Truck Will Not Start After Remote Start Fails WolfAK 6.7L Power Stroke Diesel 16 11-22-2015 10:06 AM
Truck has zero power to dash DG93 1987 - 1996 F150 & Larger F-Series Trucks 4 08-17-2015 08:45 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
