engine startup pre-luber ---- anyone have/try
anyone out there have one of these installed?
AutoEngineLube Prelube System Reduces Engine Wear Up To 60%
4 models to choose from....it will circulate some oil back into the system once the key is turned ahead of the oil pump pressure.
just wondering is the path of least resistance would be to back flush the oil filter rather than to pre lube all the bearings in the crank case. maybe no backflush is possible with a motorcraft filter with the rubber reverse flow valve.
Rasputin53
15
11-11-2015 12:32 PM
