7.3 swap
09-01-2014, 01:21 PM
on
7.3 swap
I am looking to swap my 460 bbf for a 7.3. I keep finding 2wd f350. Are the trans in a 350 2wd the same as a 250 4wd. I know i have read it somewhere, but I'm not sure if thats only for the 4spd and not a zf5.
If anyone can help me out, I'd greatly appreciate it.
09-01-2014, 01:31 PM
2wd and 4wd trans are different. On 4wd, the transfer case bolts to the back of the trans...
09-01-2014, 01:37 PM
on
I knew that for the most part, but some older bw trans have the same tail. I just wanted to make sure that didn't carry through to the any others.
on
Thank you for the quick response
09-02-2014, 08:42 PM
Rebuilt an engine. What's wrong?
posted wrong place
09-03-2014, 03:50 AM
Quote:
Originally Posted by
Dflynn926
I knew that for the most part, but some older bw trans have the same tail..
only if it was used with a divorced transfer case, or was used in the F-superduty.
and you need a diesel trans, the gas trans will not bolt to the diesel block
Patrick Zeek
03-16-2019 01:47 AM
grischow2
11-10-2016 02:15 PM
VR6Nutt
09-10-2015 05:26 PM
robjs111
06-07-2011 05:52 PM
lasthighboy
11-12-2005 08:01 PM
