What is the correct name?
I'm attempting to get a used replacement cowl/water shield for my 2001 E350 xl super duty. However searching for the name of part or part number it is confusing.
The part I need is the black plastic trim which spans the width of the top of the hood and is at the bottom of the windshield. It covers the wiper motor, linkages etc.
Looks like previous owner replaced wiper motor and didn't own a screw driver when removing the cowl. Just cracked in in several pieces.
The part your looking for is the "Cowl Vent Panel"
E-series has a right and left section (2 piece)'
Ideally, if you have a pick-n-pull near your 10-20, problem solved, cause the junk yards don't charge much for any plastic parts (no $$ in plastic)
Next would to check LKQ for a location near you, for a used/aftermarket part.
That part will interchange from at least '97 through '08, most likely beyond that too as the bodies haven't changed significantly since beginning '92.
eBay is another source if nothing available locally---shipping might be a bit much for that size part though.
Fully agree LKQ is a great resource for parts like this.
Many thanks again. Just got back from the bone yard and got the entire cowl vent screen for $20! Put some McGuires back to black on it and it looks new! Also grabbed a couple of other items like cigar lighter and the ash tray on the tunnel hump.
Also my replacement radio I snagged on eBay for $20 just arrived. The digital display wasn't working on the in the van.
Needed the retaining clip that holds the wiper motor to the linkage...dealer wanted $15.00 for it plus it wasn't in stock. Got that at the bone yard too ....for nothing.
Not sure of the difference between the two bone yards, but it suppose to be the biggest in Michigan. They drive you in a beater out to the vehicle you want parts from and then remove it for you. I guess you can call and they'll do it for you if they knew exactly what you wanted. But then you can't fill your pockets with other odds and ends.
Next projects are replacing the clock spring in steering column and to figure out why I have no AC in rear of van just blowing hot air.
Most likely you have a vacuum leak or failed vacuum servo in the rear heater case, assuming you have the factory-installed rear heat & A/C?
tonfro
02-12-2015 04:17 PM
1966Tbird
06-08-2009 11:38 AM
ford-hmm
1983 - 2012 Ranger & B-Series
04-10-2005 10:49 PM
